Username/Password Login Verification
Hi:
Is there any widget in DA or UE that allows for Username/Password Login verification? I'm using DW CS5.
Thank you for your attention
Hi:
No, neither UE or DA have User Authentication included.
There are behaviors for user authentication built into Dreamweaver (Insert -> Data Objects -> User Authentication)
Or you couls use Security Assist
Jason:
I located the behavior you mentioned. Thanks.
Is there any other behavior in DA, UA or DW that allows me to use the user's ID (the user who just logged in) to display his/her profile?
I already have the member homepage display page.
Thank you for your attention.
if you are using the Dreamweaver Authenticate user server behavior, the Username is stored in a session named "MM_Username"
to create a profile page, you need to create a recordset that filters the Username column on the MM_Username session variable.
Jason:
OK. Got it. Many thanks.
