Captcha doesn`t appear.
Thread begun 5/09/2011 12:27 am by rokla393076 | Last modified 5/18/2011 8:08 am by Jason Byrnes | 7259 views | 14 replies |
rokla393076
Hi Guys, I`m not able to get a reasonable solution for my captcha problem so I`m trying it in this way.
The problem – I can`t see captcha figures in view and/or browser mode. I adhere to the manual; at first glance everything in Dreamweaver seems to be ok until displaying the captcha functionality in a view mode. Instead of captcha figures I can see only a question mark (the datapicker works).
Thanks in advance for your kind replay.
Rokla
Most likely, the GD Library is not enabled in your php installation. See the "Enable the GD Library setting on your testing server" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
rokla393076
Dear Jason,
The GD library was and has been enabled; the problem remains. PLS was should be the next step?
Rokla
right click on the question mark where the captcha image should appear and select view image.
Does this show any error messages?
What is the address in the address bar for the page that comes up?
rokla393076
No, there is no kind of error message.
rokla393076
The address: "http://localhost/Captcha/webassist/captcha/wavt_captchasecurityimages.php?width=200&height=50&field=Security_Code_1&bgcolor=FFFFFF&transparent=0&bgimage=&gridfreq=20&gridcolor=000000&gridorder=behind&noisefreq=20&noisecolor=000000&noiseorder=behind&characters=5&charheight=&font=fonts/MOM_T___.TTF&textcolor=000000"
(Translation - the picture “webassist ....“ cannot be displayed because it contains an error)
rokla393076
I find out the error – the incorrect path „../../webassist/captcha/wavt_captchasecurityimages.php …“
Thanks for your assistance,
Rokla
rokla393076
PLS my last question - when I enter a wrong captcha this warning appears. What it stands for?
Warning: Cannot modify header information - headers already sent by (output started at /… /project/captcha.php:4) in /.../project/webassist/form_validations/wavt_scripts_php.php on line 71
see this post for details on troubleshooting the headers already sent error:
showthread.php?t=19285
rokla393076
This post has been deleted.
