Delete Folder
Thread begun 7/03/2009 6:37 am by shaun.andrews | Last modified 7/07/2009 8:13 am by Ray Borduin | 3526 views | 3 replies |
shaun.andrews
Delete Folder
Is it possible to use Digital File Pro's delete function to delete a whole folder (including all of it's contents) rather than specifying a file name?
I have a situation where I want a record and all of the files associated with the record to be deleted at once.
(including the actual folder)
I've since had a play with this tool and it does not appear to be able to do this. If you specify a record set for it to delete it only deletes the first file. Is there a way I can still achieve this?
Not without hand coding... You can probably just add code to loop through the recordset around the delete to delete all of the records from the recordset if it deletes the first row now, the loop is the only thing missing.
shaun.andrews
Hi Ray,
Are you able to tell me what the code should look like? I've got no idea how to write this!
The code that the delete file generates is:
<?php $WA_DeleteFileResult1 = false;
if(isset($_POST["yes"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("", "".$row_rs_dogphotos['photo_image'] ."");
Thank you for your help
Add a recordset and repeat region to the page. That is the code you would use. Just place it around this code instead of placing it around a visible area of the page.
