Uploading Images
Thread begun 5/22/2011 11:21 pm by jebrandon343719 | Last modified 10/12/2011 11:45 am by Jason Byrnes | 4441 views | 7 replies |
jebrandon343719
Uploading Images
In the admin, kfm uploader, I am unable see the images that have been uploaded.
I searched other forum posts and some time ago there was a browser issue. I have used FireFox and IE and still I get nothing.
There is a side colum with the word Directories , and that is it. The files are being uploaded to the folder imagesupload/cms_files ... but I cannot access them!
What is happening???
david.cooke172080
Same Issue accessing images in editor
Recently installed version 4.5 on my server - when I attempt to access to insert an image and click on the browse server button I recieve permission error
"file permissions error has occurred. Please check the permissions on the script and the directory it is in and try again"
I know it should be a simple issue of changing permissions - but what directory are images accessed from and what is the permission setting required.
Note: Out data center for security prefers not to use 777 or 666 for scripts which is understandable.
DarylBeta Tester
I ended up CHMODing the kfm and styler directories, sub-directories and all files to 755
KJT
uploaded image does not show
I have been using Powerstore 3 for over a year without any problems in regards to uploading image when adding or amending products but now I have the same problem as the author of this thread. I upload the image (at sizes recommended by data assist) and now it does not show. It is in the imageupload file when I check via ftp. I do not get any error messages when uploading image.
The only thing we have changed recently on our website is adding a new ssl certificate via godaddy.
I read on the forum about file permissions and I have tried changing that but it has no effect.
Here is a link to a recent product we have added:
Products_Detail.php?ProductID=160
Please can you advise on how to fix this problem - thanks
KJT
I am afraid there is no open support ticket for this matter in my support history?
i have recreated the ticket.
