redirect not working
Thread begun 5/25/2011 12:29 pm by mr hankey | Last modified 7/31/2013 9:33 am by dDog | 4310 views | 8 replies |
mr hankey
hi,
my data assist page is not redirecting:
code is:
// WA Application Builder Insert
if (isset($_POST["OK"])) // Trigger
$WA_connection = $cbank;
$WA_table = "parts";
$WA_sessionName = "parts_PartID";
$WA_redirectURL = "parts_Results.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "PartID";
$WA_fieldNamesStr = "PartName|SupplierID|PartSerialNumber";
$WA_fieldValuesStr = "".((isset($_POST["PartName"]))?$_POST["PartName"]:"") ."" . "|" . "".((isset($_POST["Supplier"]))?$_POST["Supplier"]:"") ."" . "|" . "".((isset($_POST["PartSerialNumber"]))?$_POST["PartSerialNumber"]:"") ."";
$WA_columnTypesStr = "',none,''|none,none,NULL|',none,''";
$WA_connectionDB = $database_cbank;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
this happens on a blank white page or any page for that fact.
is there something wrong with the code it is producing?
the form action is set to POST.
many thanks
is it inserting the data to the database?
add the following code at line 1 to see if a php error is occurring to prevent the redirect:
error_reporting
(E_ALL);
mr hankey
no errors show up and i just tested and it insets into the database fine.
so the isnert is working perfectly it is just the redirect that does not.
it just adds a "?" to the page name after insert.
many thanks
dDog
Exact same issue
Our product insert page uses both "insert record" and "insert multiple records" (for multiple categories). The products insert correctly, but does not redirect to products_Results.php.
We get error message:
Warning: Cannot modify header information - headers already sent by (output started at /home2/ahsafety/public_html/admin/products_Insert.php:47) in /home2/ahsafety/public_html/admin/products_Insert.php on line 426
Line 426 is multiple insert:
This error is caused by output to the page before the header or session_start() functions are used.
if you read the errror carefully, it states that the out put is at line 47
line 426 is just where the header function occurs.
in this case, the probelm is a blank line betweren php code blocks.
lines 45 - 47 are:
there should not be a blank line after the closing php tag at line 45 and the opening php tag at line 47.
change that to:
dDog
Doh!
Amazing how a few poorly placed blank lines can cause so much havoc. :-)
I made the correction on lines 45 - 47, and I found another blank line 391-393. After correcting both and searching for other blank lines, I uploaded and tried to insert a product again.
This time we get the error:
Warning: Cannot modify header information - headers already sent by (output started at /home2/ahsafety/public_html/admin/products_Insert.php:162) in /home2/ahsafety/public_html/admin/products_Insert.php on line 424
Looking carefully at lines 161-165:
<h1 class="text">
<?php if(WA_Auth_RulePasses("Administrator")){ // Begin Show Region ?>
Administrator
<?php } // End Show Region ?>
</h1>
This code are part of the template, and are grayed out. Is there a change I need to make the template?
you have the insert code in the page body at lines 360 - 429.
that code should be above the doctype tag.
dDog
Wah hoo!!!
It works now! Thank you for taking time to help squash these bugs. I know better now what to look for in the future.
I had moved the insert functions at the end the code thinking that would help, but I it makes sense that the insert code would have to be at the top where databridge initially placed it.
Many thanks!
