How to prevent Duplicates
Thread begun 5/25/2011 1:24 pm by kp006274029 | Last modified 9/08/2011 1:43 pm by danny405167 | 3859 views | 6 replies |
kp006274029
I have created an insert page using the data assist wizard..It has a dropdown menu which lists categories and a text box that allows the user to add a sub-category to the category in the dropdown menu. I need to allow the user to add the same
sub-category to multiple categories..i.e. both the categories Dog and Cat could contain the sub-category "LEASHS" however entering "LEASHS" twice in the Dog or Cat category is not allowed.
I know how to prevent a user from entering a duplicate, by using the standard insert
record and check username server behaviour but not sure how to do it in the above case.
Many Thanks In Advance.
KP
you would need to create a recordset to lookup the selected category and the subcategory name that is entered to see if it already exists, using Server Validation from form toolkit or CSS Form builder, you can validate that the reocrdset is empty.
in the server validation server behavior, Set the server variable to "$totalRows_RecordsetName" where RecordsetName is the name of the recordset.
Use number validation. set the minimum to -1 and the maximum to 0.
kp006274029
Thanks Jason, did the same but with validation toolkit..worked a treat. :)
you're welcome.
danny405167
I have been trying to get the duplicate to work but I am getting the following
Warning: Cannot modify header information - headers already sent by (output started at E:\vhosts\testSite\admin\users\users_Registration.php:6) in E:\vhosts\testSite\admin\users\users_Registration.php on line 92
Registration
the error is caused by the blank line at line 5.
change lines 4 - 6:
<?php require_once("../../webassist/form_validations/wavt_validatedform_php.php"); ?>
for more details on troubleshooting the headers already sent error, see the following post:
showthread.php?t=19285
danny405167
Thank you for your help; problem solved. That's very helpful link, thanks.
