3 things, 1 Error and 2 wierd things in SA2
Thread begun 5/27/2011 4:50 am by Morgan | Last modified 6/21/2011 7:39 am by Jason Byrnes | 7744 views | 22 replies |
Morgan
Hi, Exelent Extention, (if i could get it to work!)
3 things ive encounterd.
1 thing when i try create via --> Wa -> Create Security Pages wizard.
When it comes to about 80% done in the process i get a " Error in applyCookiesSB: Error nodeToOffsets: Argument number 1 is invalid"
That one repeatst 2 times after i click Ok in the popup.
See attached file.
2 thing is the URL address if i click F12 whitin Dreamweaver to open a secure page, in this case a empty index.php page. the URL gets long as i dont know. lol See attached file.
and the 3 last one
Is that i get the text "undefined" on everysingel page from the loginpage to the registrationpage. I mean on every singel page the wizard creates.
See attached file.
Is the 2 last things conected to the cookie error from the wizard?
Do i need to have Cookies Toolkit installed? - Never mind that question!
Ive tryed in Dreamweaver CS5 and in CS5.5.
Cleared the Cache file and tryed create the pages in a clean site, just a site deff and a index.php file.
Any idés?
Regards Morgan
Small Edit: I created a new Config folder and just installed SA 2, got it to work, Made a new Config-folder again and started to reinstall extensions 1 by 1. Sofar so good.
Still i get the URL string Error, F12 on a page with security on makes the URL string mega long. See attached file up in the message.
I havent activated any more Extensions yet, so i really dont know it the errors precist, sucks doh that with every new Extensions i get errors, errosrs and errors. Not talk about the bunch of Errors i got after removing AS2... Thats why i ended up making a new Config-folder!
Jim E D
undefined
Did you get an answer to the "undefined' display on each page? Getting the same thing here.
MikeH
Hi
I have also got the same issue. Its put in the top few lines of code usually betwwen PHP sections I have just removed it manually and have seen no side affects. Not sure if its something missing though.
Mike
Jim E D
Thank you!
I'll try that. thanks for the reply...
Morgan
Hi, havent got any reply yet. (Have been away so i replyed to my support ticket today.)
Thats right that the undefined text gets added in to the pages, and you can remove it from the pages.
//Morgan
Morgan
Some updates!
I get Errors when i have Form Builder 2 (Beta version 023) and AS2 installed.
Cookie Errors on Set and on Clear + i get the "undefined-text" added to all the pages.
Note: Installed FB2 first prio to AS2.
When i have Form Toolkit and AS2 installed only i dont get any errors, everything looks smooth, and works correct.
Note: Installed FT prio to AS2 installation.
I havent installed any other extensions then the 2. But i get the feeling that the Form Builder somehow ****s things up. Not 100% sure just yet, have to try some more, atm my Configurations folders starting to stack up in the Adobe folder thats for sure, lol :)
So you guys/girls that have problems try remove the Form Builder if u have that one installed, see if that sort the errors out. Hopefully the problems lays in FB2.
//Morgan
Miguel
I got the exact same problem as post one, also when i try to login i get
On the login page
html:
Warning:  Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\test\admin\entrar.php:11) in C:\xampp\htdocs\dakalan\webassist\security_assist\helper_php.php on line 55
On the registration page
html:
undefined
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\test\registration.php:7) in C:\xampp\htdocs\dakalan\registration.php on line 36
also getting the undefined on any page that has the SA2 btw i hav enot installed FB 2 beta i have the one not beta
also when editing some times the form in SA2 wizard many times gives a bunch of javascript errors making me start over and over no matter how many times i delete dreamweaver cache.
I also have a complaint this sa2 has not much for the price we had to pay just a few more encryption options everything else i already had with my supersuite extensions, it should have user levels and email confirmation stuff i feel not very happy with the new extention and the many bugs on it i really needs this to work i have a site that im out of time trying to guess how to get the extension to work correctly :mad:
Help us please
Sades
Morgan
Hi Sades, I think its FB 2 that is the problem, ive tryed FB2 and FB2 Beta (the Beta is for HTML Editor 3) get errros with both of them, atm i dont use FB2 in that way AS2 works as it should.
Yes i have tryed edit forms with FB2 too, that is not working and as you say it creates loads of Java errors.
Uninstall FB2 and AS2, delete cache, then reinstall AS2 that should make AS2 work.
Regarding your Header already sent, check that you dont have dublicated Start session on your pages.
hope this helps you out a bit.
//Morgan
Miguel
Yea checking the code there was duplicated sessions starts and also space between <?php tags, btw yes im sorry i do have fb2 beta due to i have html editor 3 to i been upgrading my extentions hope they get to fix this issue, i made a clean site and right now i have it working thank god i changed so many things i dont remeber what i did to avoid the error, what i do know is that after i have created it theres no way to change it unless you want a machine gun of javascript errors
