Unique Background Image - horizontal menu
Thread begun 6/02/2011 9:42 am by markhaynes75235 | Last modified 6/03/2011 9:24 am by Jason Byrnes | 5945 views | 7 replies |
markhaynes75235
Hi Jason et. al.!
I've got a horizontal CSS MenuWriter menu that's been working great for several months. One requirement that I've been asked to implement is to change our Donate button to a unique color at the root level of the menu. The code for the images in the menu is as follows:
ul#cssmw3 > li {
background-image: url("../cssmw3_images/left_act.gif");
background-position: left top;
background-repeat: no-repeat;
ul#cssmw3 > li > span {
background-image: url("../cssmw3_images/right_act.gif");
background-position: right top;
display: block;
ul#cssmw3 > li > span > a, ul#cssmw3 > li > span > a:link {
background-image: url("../cssmw3_images/center_act.jpg");
background-repeat: repeat-x;
color: #F1F3F2;
display: block;
font-family: Geneva, Arial, Helvetica, sans-serif;
font-size: 10px;
font-style: normal;
font-weight: bold;
margin: 0 8px 0 8px;
padding: 5px 5px 5px 5px;
text-align: center;
text-decoration: none;
text-transform: uppercase;
width: 108px;
outline-style: none;
ul#cssmw3 > li:hover {
background-image: url("../cssmw3_images/left_hover_act.gif");
ul#cssmw3 > li.hover {
ul#cssmw3 > li.current {
ul#cssmw3 > li:hover > span {
background-image: url("../cssmw3_images/right_hover_act.gif");
display: block;
ul#cssmw3 > li.hover > span {
display: block;
ul#cssmw3 > li.current > span.current {
display: block;
ul#cssmw3 > li:hover > span > a, ul#cssmw3 > li:hover > span > a:link {
background-image: url("../cssmw3_images/center_hover_act.jpg");
color: #273015;
font-weight: bold;
ul#cssmw3 > li.hover > span > a, ul#cssmw3 > li.hover > span > a:link {
color: #273015;
font-weight: bold;
ul#cssmw3 > li.current > span.current > a.current, ul#cssmw3 > li.current > span.current > a.current:link {
color: #273015;
font-weight: bold;
As you can see, the background images are from slices and I have a default image set and a hover image set. I read a thread entitled "Main Menu Level - Different Backgrounds?" and tried the technique by editing the <li> tag in the menu.php file:
<li><span><a href="<url goes here>" target="_blank" style="background-image:url(../cssmw3_images/<image source file>)">Donate Now</a></span></li>
but when I load the page it still shows the original background from the menu.css.
Any help would be appreciated!
markhaynes75235
Hi Gang: I've been able to get the center image to show up but using this code:
<li style="background-image:url(CSSMenuWriter/cssmw3_images/MainNav_Donate_left_s01_1.gif)" style="background-position:left top" style="background-repeat: no-repeat"><span style="background-image:url(CSSMenuWriter/cssmw3_images/MainNav_Donate_right_s01_1.gif)" style="background-position:right top" style="background-repeat: no-repeat"><a href="https://<link to donor form>" target="_blank" style="background-image:url(CSSMenuWriter/cssmw3_images/MainNav_Donate_center_s01_1.gif)" style="background-repeat: no-repeat">Donate Now</a></span></li>
I'm not getting the proper images on the right and left - any pointers?
Thanks as always!
markhaynes75235
Ok I've gotten a bit further - now I need to figure out how to code the Hover for the three images in question. Thanks in advance!
markhaynes75235
Perhaps I need to use a custom class for this - if you have any suggestions on how to structure this, I'd appreciate any pointers.
Thanks as always!
since you want to control all aspects, including hover, you would be better setting each menu Item LI tag to have a unique ID:
<li id="donate"><span><a href="<url goes here>" target="_blank">Donate Now</a></span></li>
then create rules to target the indvidual ID such as:
ul#cssmw3 > li#donate
ul#cssmw3 > li#donate > span
ul#cssmw3 > li#donate > span > a, ul#cssmw3 > li#donate > span > a:link
ul#cssmw3 > li#donate:hover
etc...
basically copying each existing style, and targeting to the specific ID using "#idNmae" after the LI
this way you can still control the pseudo classes like :link and :hover
markhaynes75235
Thanks Jason, I'm almost there, but when I view my page, All of the center images are the new center image for the donate menu!
Here's the line in the menu.php:
<li id="donate"><span><a href="{link to donation form here}" target="_blank">Donate Now</a></span></li>
and the CSS as per your instructions:
/* code for custom donation menu */
ul#cssmw3 > li#donate {
background-image: url("../cssmw3_images/MainNav_Donate_left_s01_1.gif");
ul#cssmw3 > li#donate > span {
background-image: url("../cssmw3_images/MainNav_Donate_right_s01_1.gif");
display: block;
ul#cssmw3 > li#donate > span > a, ul#cssmw3 > li > span > a:link {
background-image: url("../cssmw3_images/MainNav_Donate_center_s01_1.gif");
color: #F1F3F2;
display: block;
font-size: 10px;
font-style: normal;
font-weight: bold;
text-align: center;
width: 108px;
ul#cssmw3 > li#donate:hover {
background-image: url("../cssmw3_images/MainNav_Donate_lefthover_s01_1.gif");
ul#cssmw3 > li#donate.hover {
ul#cssmw3 > li#donate.current {
ul#cssmw3 > li#donate:hover > span {
background-image: url("../cssmw3_images/MainNav_Donate_righthover_s01_1.gif");
display: block;
ul#cssmw3 > li#donate.hover > span {
display: block;
ul#cssmw3 > li#donate.current > span.current {
display: block;
ul#cssmw3 > li#donate:hover > span > a, ul#cssmw3 > li:hover > span > a:link {
background-image: url("../cssmw3_images/MainNav_Donate_centerhover_s01_1.gif");
color: #273015;
font-weight: bold;
ul#cssmw3 > li#donate.hover > span > a, ul#cssmw3 > li.hover > span > a:link {
color: #273015;
font-weight: bold;
ul#cssmw3 > li#donate.current > span.current > a.current, ul#cssmw3 > li.current > span.current > a.current:link {
background-image: url("../cssmw3_images/MainNav_Donate_centerhover_s01_1.jpg");
color: #273015;
font-weight: bold;
/* end code for custom donation menu */
Now all center nav images in the other menus use the center images for the donate menu in both states, but the Left and Right images are the correct images - let me know what I did wrong!
Thanks!
markhaynes75235
OK I figured it out. I added an id to the other LI tags named "default" and then edited the appropriate CSS, including the #default id value - now everything is working as expected. Thanks for your pointers!
you're welcome.
Mike Perry
I'm having trouble implementing this with current pseudo-class.
The following code works for the basic link and for the hover pseudo-class:
ul#cssmw > li#productsNav {
background-image:url(../../images/productsRed.png);
background-repeat:no-repeat;
background-position:center;
ul#cssmw > li#productsNav:hover {
background-image:url(../../images/productsWhite.png);
The following code fails to change the background image for the current pseudo-class:
ul#cssmw > li#productsNav:current	{
The address bar includes products.php; the menu.php code follows:
$WA_menuDir
getcwd();
chdir(dirname(__FILE__));
require_once(
"../../webassist/framework/library.php");
require_once(
"../../webassist/framework/framework.php");
chdir($WA_menuDir);
$WA_Menu = new WA_Include(__FILE__);
<ul class="level-0" id="cssmw">
<li id="recipeNav" style="width:130px;"><a href="../../recipe.php"></a></li>
<li id="performanceNav" style="width:200px; text-align:center;"><a href="../../performance.php">Performance</a></li>
<li id="tasteNav" style="width:100px;"><a href="../../taste.php">Taste</a></li>
<li id="productsNav" style="width:140px;"><a href="../../products.php">Products</a></li>
<li id="buyNav" style="width:180px;"><a href="../../wheretobuy.php">Buy</a></li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
$WA_Menu
->Initialize(true);
echo(
$WA_Menu->Body);
Help??
Mike
i would need a link where i can see the problem to investigate
