customer_order_details.php
Thread begun 6/08/2011 2:24 pm by cicyou421883 | Last modified 6/15/2011 10:07 am by Jason Byrnes | 5244 views | 12 replies |
cicyou421883
Items are in Database, orders and orderdetails
Trying to make the pages for looking at order history.
Unknown column 'WADAOrderID' in 'where clause'
cicyou421883
Where Clause
The database is not seeing the page that I created with Webassist I am hosting with Godaddy and they use Starfied technolgies for the database, which is accepting products and orders.
the error Unknown column 'WADAOrderID' in 'where clause' is because the recordset on the order details page is missing a parameter.
edit the recordset, in advanced view, create a new variable in the variables section:
Type: Number
default Value: -1
Run Time Value: $_GET['OrderID']
cicyou421883
Recordset Attempt
Hey Jason- 2 things happen. Type: only choice says "Floating Point Number" - Is it okay to choose? When I did and hit okay Error:
Please enter a SELECT Statement
WADAOrderID is an invalid variable name; it does not appear in the SQL
I used e-commerce for the SQL
Thanx again, Cathy
there should be a selection for integer, use that one.
it sounds like you are createing a new recordsert not editing the existing record set on the order details page.
Double click the WADAOrders recodset on the order details page to edit it.
cicyou421883
Same error message
Changed the variable with your instructions, uploaded to site and same error comes through
Retosred .msql file in database to make sure.... all WA files were put... Any more ideas? Right now I am amually going into the database. Thanx, Cathy
make a visual change to the page and re upload it to ensure that the upload is actually going up.
If you can versify that the code changes are actually making it to the server, and still have the same issue, send a copy of your page so I can view the code.
cicyou421883
verified put successful
The page is uploaded, refreshed and verifies. Error still there, Sending Attachment - Thank you!
Sorry I sent it the wrong way - shame on me - I knew better. learning still. Will this zip work?
please dont paste the code into a word doc, it is completely unreadable this way.
compress the original php file into a zip archive and send the zip file.
cicyou421883
Changed the file
Changed the file, Thanx
