DFP 2.1 whole new suite of errors
Thread begun 7/06/2009 10:43 am by dreamweaver41056 | Last modified 7/07/2009 12:25 pm by dreamweaver41056 | 8751 views | 15 replies |
dreamweaver41056
I updated DFP 2 to DFP 2.1 this morning and now I have problems and more problems.
1) Added file field to insert form and added upload behavior. All of my information was populated correctly.
2) Modified insert behavior to populate image and thumbnail fields
3) Tested the page and the only thing that happened was the default file name was populated, in this case ../images/spacer.gif
So I decided to go through the page again to make sure everything was right. First I compared it to a page I built a month ago s ago using DFP 2 with the new helper file provided as a temporary patch for the DFP 2 extension. Upon this examination everything looked correct. I tested the old page to make sure it was still uploading and populating correctly and it was.
Then I clicked the server insert behavior on the new page and get the following error,
"'While executing onLoad in WAAB_Insert_SB.htm, the following JavaScript error(s) occurred:
In file "WAAB_Insert_SB";
initializeUI is not defined'"
Tried to inspect the behavior on the good working file and get the same error.
Closed and restarted Dreamweaver and get the same error on every page with an insert behavior.
So, it appears that DFP 2.1 has broken Data Assist (which I did not update) or Dreamweaver.
Now I'm dead in the water and can't do the work my clients were depending on me to do.
Please delete your winfilecache .dat file with DW closed. That will fix these errors. It is a problem with the cached version not matching after updates and a false error being reported by DW.
dreamweaver41056
DFP 2.1 still broken
I deleted the winfilecacheXXX.dat file and that corrected the DataAssist error but the file upload is still not working.
Here is my code:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../prodimages/",
'FileName' => "[FileName]",
'DefaultFileName' => "../images/spacer.gif",
'ResizeType' => "2",
'ResizeWidth' => "650",
'ResizeHeight' => "0",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1_2 Start
$WA_UploadResult1_Params["WA_UploadResult1_2"] = array(
'FileName' => "[FileName]_thumb",
'ResizeWidth' => "200",
// WA_UploadResult1_2 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "ensembleImage", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
OK... do you get an error or what happens. I would have to have a complete description of the problem and the entire page to tell why something might not work.
Even then if it is a server configuration error of some sort there may not be a problem to spot.
I guess what I am saying is that that part of the code looks correct to me.
dreamweaver41056
No error messages
No errors and the pages that I built a month ago are all working fine. The upload code for the older page I alluded to is almost identical and it works fine.
--------older working page upload params------
'DefaultFileName' => "../prodimages/clear.gif",
'ResizeWidth' => "450",
'ResizeType' => "3",
'ResizeWidth' => "0",
'ResizeHeight' => "200",
WA_DFP_UploadFiles("WA_UploadResult1", "ProdImage", "3", "[ExistingFileName]_[Increment]", "true", $WA_UploadResult1_Params);
You can access any error messages for the failed upload from the bindings panel.
I would have to look at the whole page to see the problem. It doesn't appear there is a problem in the code you are providing so the issue has to be elsewhere.
dreamweaver41056
bindings panel?
I added a debug block to the top of the page and still got no errors. I have not looked at the server logs but will do that shortly. What do you mean "error messages...bindings panel"?
dreamweaver41056
PHP Notice: Undefined variable: firstFile in /var/www/vhosts/foofoofoo.com/httpdocs/WA_DigitalFilePro/HelperPHP.php on line 334,
dreamweaver41056
else{
$fileParams = func_get_arg(5);
foreach($fileParams as $key=>$val){
$defaultFileName = $val["DefaultFileName"];
$WA_DFP_UploadStatus[$statusName][$key]["statusCode"] = 0;
$WA_DFP_UploadStatus[$statusName][$key]["serverFileName"] = $defaultFileName;
$path_parts = pathinfo($defaultFileName);
$WA_DFP_UploadStatus[$statusName][$key]["fileExtension"] = '';
$WA_DFP_UploadStatus[$statusName][$key]["errorMessage"] = "No file uploaded";
$counter = 0;
if($counter == 0){ // set first upload values into V1 status values
$_SESSION[$sessionName] = $defaultFileName;
foreach($WA_DFP_UploadStatus[$statusName][$key] as $subkey=>$subval){
$WA_DFP_UploadStatus[$statusName][$subkey] = $subval;
$counter++;
if (file_exists($firstFile)) {
unlink($firstFile);
return;
Maybe debug with:
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1") ;
var_dump($WA_UploadResult1_Params);
die();
