Missing a "/" in path to file in subdirectory
Thread begun 6/10/2011 11:07 am by randyrie405335 | Last modified 7/27/2012 8:04 am by Jason Byrnes | 7357 views | 15 replies |
randyrie405335
I'm using several subdirectories and when creating a link to an uploaded file that's in a subdirectory, the pathing fails to add a "/" slash and the resulting link will not work. e.g., When I select <other> then 'Browse Server' to the file in a subdirectory, I get a wrong path:
/FileUploadsSubDirectory/MyFile.pdf ... the "/" between the FileUploads and the SubDirectory is not inserted.
How do I correct this so my users can upload a file and correctly link to the file in the Editor?
hast302969
Same problem / missing from long url
I got the same problem with / missing in the link.
codamedia
Hi Jason,
I've had this same problem, but found a work around for it (until it is fixed).
The problem appears to be in "webassist/kfm/configuration.php", approximately line 29. (it's line 29 on my system, but I guess that could vary)
$kfm_userfiles_address = '../../path/to/folder';
The above line should include a closing "/" (../../path/to/folder/)
I can manually code that slash in, however if I were to edit the file manager uploads from the HTML Editor server behaviour, it strips the closing slash out and I have to put it back in again manually.
It's a quick update on one file for me so I'm not worried about it, but would like it fixed :)
what version of HTML editor? I believe this was fixed in the 3.0.2.
codamedia
You may be right Jason. I just updated the editor the other day, and I don't know that I have worked with the new editor yet.
I will give it a try and let you know one way or the other.
codamedia
I just confirmed that I have HTML Editor 3.0.2, and installed it on a clean site. I am getting the same results as described in my previous post.
This is not a big concern, and is a really quick fix. But I still have the problem.
randyrie405335
This qwik-fix works...
Originally Said By: codamedia
  Hi Jason,
Have you heard anything more about a permanent fix from the folks at WebAssist? (I've had no luck getting them to respond).
randyrie405335
Update - Just got a fix from Webassist
  Hi Jason,
-------------- From WebAssist ---------
Posted By: ray@webassist.com (Ray Borduin) Message 4 in Log
Date: 06/20/2011 06:59 pm No Attachments
Title: RE: Missing a
Open the file:
line 27 should be updated from:
$kfm_userfiles_output = rel2abs($kfm_userfiles_address,dirname(__FILE__));
$kfm_userfiles_output = rel2abs($kfm_userfiles_address,dirname(__FILE__)) . "/";
