Populating forms . . .
Thread begun 7/08/2009 2:27 am by wetware | Last modified 7/17/2009 11:14 am by wetware | 13734 views | 29 replies |
wetware
How does one "populate" the Shipping info from the Billing info on the CustomerInfo page using a checkbox ie: "Shipping info same as Billing?" Apparently, there's some JavaScript for the checkbox trigger available from WebAssist?
Plus, I'm having "page-to-page" population problems, as well. Have followed the eCommerce Recipes360 binding instructions (CustomerInfo > Checkout) to no avail . . .
Thanks in advance!
CraigRBeta Tester
copy shipping
There is a javascript file called copyShipping.js in the WA_eCart folder.
include the link in your head section like this, (or whatever the correct path is in your case)
<script src="/WA_eCart/Scripts/copyShipping.js" type="text/javascript"></script>
In the table for shipping information, you need to call the script
<tr>
<td><input type="checkbox" name="eC_SameAs" id="eC_SameAs" value="1" onClick="eCart_copyBillingToShipping(this);" /></td>
<td><label for="eC_SameAs">Same as billing address</label></td>
</tr>
If the fields in your address/shipping tables are different from the default, it is quite straightforward to edit the javascript file.
wetware
Cross-pollinating fields. . .
. . . thanks CraigR - had the script in place, but not the "call".
We'll see how the field-naming goes in a minute.
Anyone have experience as to why the "CustomerInfo" fields don't populate the "Checkout" page? Is it a failure re: the same theory (field-naming)?
Following the eCommerce Recipes (v3) is semi-confusing while dealing with v4.1.5 . . .
Thanks in advance!
CraigRBeta Tester
do you mean the billing and shipping information displayed in the confirm page ?
this comes from data posted from the field names in the checkout form
wetware
Not getting it . . .
. . . say hey, CraigR - this is a non-database site.
The page sequence here is:
TWF_Product_Fishshapes01.php (one of a few)
TWF_Artisans_ShoppingCart.php
TWF_Artisans_CustomerInfo.php
TWF_Artisans_Checkout.php
Somehow, the Spry validation hasn't prevented empty fields being OK'd (in "CustomerInfo" pg.) & "Checkout" page then being accessed (Spry since disengaged), that same "CustomerInfo" page isn't passing info from Billing to Shipping sections (within said page), nor is it sending any info to the "Checkout" page . . .
"Checkout" page is receiving the Tax amount from the "Shopping Cart" as a "Total" price addition, but the field label & breakdown for Tax isn't delineated or displayed . . .
The Recipes360 sections on binding info, etc. have been followed, but obviously not followed - Yikes!
CraigRBeta Tester
first check your path to the copyshipping.js file as when I looked at the source using firebug, the file couldn't be found.
wetware
Path structure . . .
WA eCart directory gets placed one tier above the "main" directory by default (in my world).
Here's the coding WebAssist has placed before the HTML doctype etc. on the "CustomerInfo" page:
//WA eCart Include
require_once("../WA_eCart/eCart1_PHP.php");
$eCart1->GetContent();
//WA eCart Check Out Update
if (isset($_POST["eCart1_Checkout_1"]) || isset($_POST["eCart1_Checkout_1_x"])) {
$eCart1->UpdateCart();
$eCart1->cartAction = "CheckOutUpdate";
//WA eCart Redirect Check Out
$Redirect_redirStr="TWF_Artisans_Checkout.php";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Checkout";
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
wetware
Related issue?
When the following address:
webscr
is placed into this equation
$Redirect_redirStr="https://www.paypal.com/cgi-bin/webscr"; "
in the //WA eCart Redirect Check Out" area on the "Checkout" page, the "Proceed to Checkout" action of the "CustomerInfo" page results in an immediate transfer to this PayPal website. The "Checkout" page is bypassed altogether. That is, it's bypassed as a visible/actionable page to the person involved in the transaction.
So, I've left that "entry" out so as to troubleshoot the field population issue - but, for you wondrous Sherlock Holmsian folks out there, it might be a clue!
CraigRBeta Tester
Ok found it this time.
Don't know what was wrong before, but i can see it now.
in your copyShipping.js file, the field names which are used are different from those on your form.
you have to either change the field name on the js file or on the form.
eg try firstname and shipping_firstname for the relevant tables on your checkout page
wetware
Isn't it odd . . .
. . . that a WebAssist binding tutorial, a WebAssist .js file, and a WebAssist snippet collection should have differing field names? The function of tutorials would seem to be one of enlightenment through "correct" examples that would be roadmaps for success . . .
But, paying attention is my job ultimately, so . . .
Thanks, CraigR, for sticking with this quest - I'm sure that there are more pitfalls that I will fail to navigate . . .
Thanks for the clue, I'm eager to see where it leads!
