spry widget text field err
Thread begun 7/19/2011 8:01 pm by jon426081 | Last modified 7/21/2011 10:12 am by Ray Borduin | 4790 views | 7 replies |
jon426081
Having problems after I ran Security assist.
wholesalersregister.php
Getting an error message.
Also, the captcha thing doesn't show up. i'll probably delete it, and use the security question instead, but I was wondering for the future what to do with that as well.
Any help would be appreciated! thanks!
find the following line:
var Registration_group_Confirm_Spry = new Spry.Widget.ValidationTextField("Registration_group_Confirm_Spry", "undefined", { isConfirm:true , validateOn:["blur"]});
and change it to:
var Registration_group_Confirm_Spry = new Spry.Widget.ValidationTextField("Registration_group_Confirm_Spry", "none", { isConfirm:true , validateOn:["blur"]});
for the captcha, if I try to browse to the file that is supposed to generate the captcha image directly:
wavt_captchasecurityimages.php
i get a 404 error message suggesting that file is not uploaded to the server.
jon426081
Invalid Information
Thank you. That's all squared away now.
But now when I fill out the form, its producing this message "Invalid information, please check your entries and try again."
But the fields are all correct and the database is set up properly. I attached a screen shot of it to reference in case that helps.
Thanks again!
that is saying that the validation has failed,
send a copy of your page in a zip archive so i can inspect the code.
jon426081
buffalo, tomove
its attached, please let me know if I did that correctly.
you have removed the captcha and security aquestion form elements, but noit the captcha validation code.
delete the following 2 lines
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code"]))?strtolower($_SESSION["captcha_Security_Code"]):"") . "",true,15);
  $WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Answer"])?$_POST["Security_Answer"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,16);
for any form elements you remove, you need to remove the validation as well.
jon426081
update page error
Jason,
Thank you for your patience all of my issues are resolved with the registration page.
However, I am now getting an error similar to my first one, but for the update page. I tried finding the same code, to replace it, but its not in this particular document.
I attached the zipped code for you to see.
here is the URL
wholesalersupdate.php
(i took the restrict access off).
It is practically the same line of code... upate:
var User_Update_group_Confirm_Spry = new Spry.Widget.ValidationTextField("User_Update_group_Confirm_Spry", "undefined",
var User_Update_group_Confirm_Spry = new Spry.Widget.ValidationTextField("User_Update_group_Confirm_Spry", "none",
