Thumnail images not displaying
Thread begun 7/22/2011 4:11 pm by tiabradford427079 | Last modified 9/29/2015 2:37 pm by Ray Borduin | 6138 views | 19 replies |
tiabradford427079
Hello,
I have the backend administration of my shopping cart set up and working properly. However the thumbnail image does not display in items_Detail.php. I have this info in my properties panel under Src.
<img src="../images/art/thm/<?php echo $row_WADAitems['ItemImage']; ?>" alt="" id="WADAPageHeaderImage" />
My images folder is in the site root. I tested the path through the browser to the images and the pics show.
Any ideas?
Does your ItemImage field in the database have the full image name including the extension like: "myimage.jpg", or is it incomplete? Look at the source code on the page to see the full resulting code and see if you can spot the problem.
It is probably an issue with the insert into the database and not with the display.
tiabradford427079
I did as you instructed an yes the extension is showing for the images.
View the source code on the page displaying the image. Does the <img src=""> value for the src look correct to you? It must be wrong somehow. Do you have a url where I can view the page?
tiabradford427079
Here is the info from the WADAHeaderPageArea. I am using Security Assist so to view it you would need a username and password. The path is correct to where the images are. I made sure to remove the height restriction from the CSS
<div id="WADAPageHeaderArea">
<div id="WADAPageHeaderImageArea">
<img src="images/art/CelticMandala.jpg" alt="" id="WADAPageHeaderImage">
</div>
<div id="WADAPageHeaderInfoArea">
<div id="WADAPageHeaderItemName">
CELTIC MANDALA
</div>
<p id="WADAPageHeaderItemDescription">
&nbsp;
</p>
<div id="WADAPageHeaderButtonPrice">
<div id="WADAPageHeaderButton">
</div>
<div id="WADAPageHeaderPrice">
700.00
</div>
<div class="WADAClearBoth">
</div>
</div>
</div>
The path must be incorrect... or else it would work.
Maybe it should be:
<img src="/images/art/CelticMandala.jpg" alt="" id="WADAPageHeaderImage">
Is your page in a subdirectory? Is the image folder in a different directory?
tiabradford427079
yes, my page items_Detail.php is in a folder in the root called Admin. From the root, my images are inside of a folder named art which is inside the folder called images.
so from the root of the site, the path to images is:
/Admin/images/art/CelticMandala.jpg ?
Can you send me a link to the image and the url to the page? I should be able to see the image without logging in and won't need to actually view the page I just want to see the path.
tiabradford427079
tiabradford427079
That is a link to the larger image.
I have another sub directory images/art/thm/celticmandala.jpg
I would like to use these thumbnail images. Here is the link
