'Capitalizing' a form-field inserted by DA
Thread begun 7/31/2011 1:20 pm by Paul | Last modified 8/01/2011 3:13 pm by Paul | 2506 views | 4 replies |
PaulBeta Tester
I'm using DA to insert a new user record into MySQL table.
I have the form configured so each word typed into each field is 'capitalized' using 'text-transform:capitalize', however the insert process does not keep that 'capitalized' format and inserts all in lowercase.
Here are the two fields i wish to insert as 'capitalize'
GetSQLValueString($_POST['fname'], "text"),
GetSQLValueString($_POST['lName2'], "text"),
Any ideas please?
Thank you.
Paul
Mike Perry
Originally Said By: paul.casbourne361959
Any ideas please?
Thank you.
Paul
Your changing the style of the displayed text -- that isn't changing the actual data. Look up the PHP functions 'ucfirst' or 'ucwords'. . .
PaulBeta Tester
I should have added that i've seen some examples of ucwords, which is what I believe i should be using, but what is not clear to me is where/how to use it.
For example
GetSQLValueString ucwords(($_POST['fname'], "text")),
and
GetSQLValueString ($_POST[ucwords('fname')], "text"),
and
GetSQLValueString ($_POST(ucwords(['fname'])), "text"),
Seems obvious to me, but do not work.
I believe the code you are editing here is a part of the Dreamweaver recordset, not the data assist insert.
in the data assist insert behavior, when you bind a column to a form value, it will show code similar to this in the value section:
<?php echo((isset($_POST["textfield"]))?$_POST["textfield"]:""?>
you would want to edit that code to use the ucwords() function:
<?php echo((isset($_POST["textfield"]))?ucwords($_POST["textfield"]):""?>
PaulBeta Tester
Thanks Jason,
I have reverted back to DA to allow the above modification.
(not sure why i used DW in the first place!)
MySQL now populating with capitalized words.
Pefect.
