Multiple Addresses destroys map
Thread began 8/04/2011 2:26 am by iansheldon422428 | Last modified 8/05/2011 10:00 am by Jason Byrnes | 3324 views | 11 replies |
iansheldon422428
I have implemented a map that pulls back addresses from a recordset.
The problem is, whilst it pulls back the first address fine it then stops there and in turn destroys the visibility of the map.
Even as you drag around the map area parts dissapear. It works fine if I just pull a single address back from the recordset.
I'm hoping there is an easy fix to this! :-)
Cheers
Ian
please post a link where i can see the problem.
It's impossible to tell what the fix may be without knowing what is causing the problem, to tell what is causing the problem, I need to see it.
iansheldon422428
Hi Jason,
It's all built within a password protected system at the moment.
What I will do is try and create a standalone page to replicate the problem and give you the URL for that.
Cheers
Ian
another option is to view source on the page in the browser and send a copy of the page source, I might be able to spot the problem that way.
iansheldon422428
Hi Jason,
Thanks for your help.
Is the attached enough for you to work with to troubleshoot?
Cheers
Ian
page.txt
The issue i see is that the street address in the code is coming out as [Address]:
street: '[Address]',
city: '',
state: '',
zip: 'ST2 7LE',
country: '',
infowindow: 'default',
which is causing the map to break.
iansheldon422428
Hi Jason,
Thanks for coming back to me.
I've had a quick look and changed the map (recreating it, again based on the multiple addresses from recordset).
Same problem though i'm afraid, and when I look at the source there seems to be no attempt at it getting past the first record (there are 5 records in total).
Let me know what you think.
Best Regards,
Ian
helpdesk_mydiary.zip
in the source code, i can see that there are 5 addresses, but each one is exactly the same:
var address_0_x = {
street: '',
city: '',
state: '',
zip: 'ST2 7LE',
country: '',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong>Address:</strong><br />[Address]<br /> ST2 7LE</span>',
full: '[Address], ST2 7LE',
isdefault: true,
addressType: 'address',
loop: 'rsmaps',
latitude: '',
longitude: '',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
the full address for all 5 is:
can you send a copy of the google_javascript/wagmp_map_2php file so i can see how that was configured.
iansheldon422428
Of course Jason, here you.
This is unmodified so as created by the Wizard.
Cheers
Ian
wagmp_map_2.zip
on your pain page, double click the rsdayjobs recordset and click the test button, send a screen shot showing the data returned from the recordset.
