On Server Side Validation "Not Like Entry"
Thread begun 8/09/2011 10:11 am by neo314 | Last modified 8/09/2011 3:08 pm by neo314 | 2316 views | 2 replies |
neo314
This message is for Ray,
I was looking into Server Side Validation "Not Like Entry" and came upon this thread: forumdisplay.php?f=28
In it, you posted:
  I suppose you could do it with a little php...
Use required validation on :
<?php echo((isset($_POST['firstField']) && isset($_POST['lastField']) && strtoupper($_POST['lastField']) == strtoupper($_POST['firstField']))?"fail":""); ?>
that should fail required validaiton if the two fields were the same... just a warning though... I knew a kid named "Jackson Jackson" in high school.
This confuses me a bit. Could you please explain. If the 2 fields are the same, this statement outputs "fail" which should pass required validation right? fail is an input, BUT if the two are not the same it outputs "" which should fail required validation. Am I missing something.
It would be nice if this feature were added to validations without having to resort to trickery.
in the example given, "failed" is just a string used to pass validation. the string can be replaced with anything. it could be replaced with "passed", "123" or even "donald duck".
<?php echo((isset($_POST['firstField']) && isset($_POST['lastField']) && strtoupper($_POST['lastField']) == strtoupper($_POST['firstField']))?"123":""); ?>
neo314
That is what I thought, but I believe the logic is backwards for "Not Same As" validation. I just debugged mine and my belief seems to be correct.
If the statement is true, and they are the same it should fail so it should be ...)?"":"123";
I just finished debugging mine. I am doing something a little different, but the same general idea. I'm using file with overwrite as the option for same file names, so I create a recordset that searches existing fields for the posted file name and use your method for checking that the posted file name is not already in the database (on the update page it will have to screen out the record being updated WHERE ... AND id != $_POST["WADAUpdateRecordID"])
The statement I am using which is working for this purpose is:
<?php echo((isset($_FILES["musicfile"]) && ($_FILES["musicfile"]["name"] == $row_filecheck["musicfile"]) && ($totalRows_filecheck > 0))? "":"Pass"); ?>
