Premiere Ticket other Questions...
Thread begun 8/31/2011 2:42 am by Sly Verano | Last modified 9/26/2011 7:51 am by Jason Byrnes | 6520 views | 9 replies |
Sly Verano
Hello,
I'm creating now the send a private message to users...
I just want to ask ... what is the format of the filter should I used in my record set. To view the messages that I owned. To avoid the viewing of other messages of the users. How was that?
Thanks ... :)
when you log in a session variable is created with your users ID number, use that session variable to filter the messages on the User ID column of your messages table.
Sly Verano
Professor will create the class page for their student
Thanks Jason. It works. I already have my sentbox features at my webpages. Your Very
Genius.
I have my another question regarding to my comment system.
Now I want the comment system is inside of the classpage.php of what the professors created ...
What is my first step to implement this feature ?
1.) How can the professor create a new classpage.php, for me to able to add the comment system inside that classpage.php.
2.) After the professor created the classpage.php, How could the professor add a student to that classpage.php ?
3.) How could the student join to that classpage.php ?
Thanks in Advanced Jason ...
you dont create a new physical file. On the classpage.php file, you create a recordset to look up the class by ID.
you would have one page that listed all of the classes with a link top the classpage.php file, that passes a querystring variable. The technique is reffered to as a master details page set:
WScbb6b82af5544594822510a94ae8d65-78b7a.html
I think you are missing some basic MySQL relational data concepts that will be needed to get this working.
in a mysql database, all of your tables will have a primary key column.
for the classes table, there will be a primary key column that uniquely identifies the class.
for the student table, there will be an ID column that uniquely identifies the student.
In MySQL you use these ID values to create relationships between the data.
there are 2 basic types of relationships:
1) One to Many
2) Many to Many
One to many relationships are pretty easy, but many to many relationships are more difficult.
With assigning students to classes, you are talking about a many to many relationship.
the idea with a many to many relationship is to create a linking table.
for example, if you have a students table:
students:
studentID - Primary Key
studentName - text
etc...
and a classes table:
classID - Primary Key
className - text
etc
you would need to create a studentClasses linking table:
studentClasssID - Primary Key
studentClassStudentID - relates to students.studentID
studentClassClassID - Relates to classes.classID
for the professor to assign students to the class, you needs to create a page where the professor selects the student, then selects the class and inserts the student ID and the Class ID to the studentClass table.
for the student to sign up for a class, when they login, their ID will be stored in a session variable, you need to set up a page where the student selects the class, then ID session variable and the Class ID are stored to the studentClass table.
Sly Verano
Thanks Jason for a very clear explanation.
In my class table I have 3 primary keys ... those are (PKsecSectionCode, PKsecSectionSchoolYear,PKsecSectionSemester) because in every school year and semester the SECTION CODE of the class is repeating. for example (the section code is:M001, SY is 2011-2012, let say the semester is 1st Semester) ...
and when the 1st Semester is already finished,.. there is a 2nd semester so (SECTION CODE is M001, SY is 2011-2012, SEMESTER IS "SECOND SEMESTER")
So to avoid the duplication of the Row I used multiple PRIMARY KEYS of the my Class table.
1.) Is my class table structure for my database is correct ? because this is my first time to used the MULTIPLE PRIMARY KEY in a table.
2.) Now I want to join this MULTIPLE PRIMARY KEY table to other tables ... can you help give me some PATTERNS AND HINTS in JOINING A TABLE (already have the relationship of my tables)
THANKS IN ADVANCED ... :)
no, using multiple is not correct.
you should only have one Primary key column.
the primary key column should use an Integer as the data type, and it should be set to automatically increment.
the primary key column should be a numeric value that is controlled by the database.
The section, school year and semester columns can be indexes in the table, but they will not be the primary key.
the way I would create the table is:
classID - Primary Key, auto increment
classSection - text
classYear - text
classSemester
you will have records that look like this:
| classID | classSection | classYear | classSemester |
| 1 | M001 | 2001 - 2012 | First |
| 2 | M001 | 2001 - 2012 | Second |
| 3 | M001 | 2001 - 2012 | Third |
| 4 | M001 | 2001 - 2012 | Fourth |
the value to use to create the relationship to a first semester or third semester class would be the classID column.
I strongly suggest looking at your local bookstore for some books on MySQL database design.
Sly Verano
Thank You very much Jason. Accept my humble gratitude to you. You always give me a
clear direction regarding my Capstone Project. :) I don't have any regret to join this
community. All the engineers in WA are very genius and very supportive to their fellow
customers. Keep it Up.
1.) So If I set the the section, school year and semester columns to indexes. What is the
purpose of that indexes.
classSection - text
classYear - text
classSemester
2.) If I set the datatype of the classSection,classYear,and classSemester to Datatype:TEXT and when I set it those column to index this error occur
ERROR: Error 1170: BLOB/TEXT column 'secSectionCode' used in key specification without a key length
3.) What can you suggest of datatype if I will set those column into Indexes.
Thanks in Advanced Again ...
You really need to do some reading on MySQL,
see the following page on the MySQL Site for a description of indexes:
mysql-indexes.html
2- 3) The usual text data type to use is varchar
Sly Verano
Hi Jason,
how can I joined these kind of relationship table ... I want the cloumn className to be part of my table studentSection. but when I joined the column className into the table studentSection. And put insert the rs_className into my page. there is no record appear when check into the browser.
  students:
studentName - text
etc...
class table: (parent)
classID - PRimary key
className - text
etc ...
and a section table:(child of class)
sectionID - Primary Key
sectionName - text
classSectionClassID - relates to class.classID
etc
studentSection(child of section table and student table) many to many relationship (but I want to joined the className column to my recordset to view the className of that section)
studentSectionID - Primary Key
studentSectionStudentID - relates to students.studentID
studentSectionSectionID - Relates to section.sectionID
Advanced Thanks...
when the class is inserted, a session variable is created that contains the class ID.
This session should be used in the section.classSectionClassID column when inserting the section record.
