PowerGallery2 can't update galleries
Thread begun 9/11/2011 10:59 am by tiffanyginestra363654 | Last modified 9/01/2012 11:57 am by Patrice | 4490 views | 12 replies |
I have upload/installed the upgrade for PowerGallery2
Strange things are happening and it's not working correctly.
I have a gallery selected to edit
Then click the manage images...
1.) it won't let me change the image info for more then just image 1
2.) it's having a hard time loading the images
Then I go back to upload images, and the title of what gallery I'm on changes to a number and it creates a new gallery (with that number) on it's own.
What is going on here!?
PowerGallery1 was working perfect, now I don't know what to do.
Vinicios Nussemeyer
If someone managed to solve the problem, PLEASE share with other users PowerGallery 2
I am also having the same problem. The PowerGallery 1.x worked perfectly. 2.0 PowerGallery bought the day it was released (Date: 08/27/2011 08:55 pm) and still can not use it. The same thing happens, the gallery I just created changes name (it appears a number), the images that I upload the admin PG did not appear and returns a message for me to upload images. I've applied the CHMOD 0755 and 0777 in all the folders but does not work. It deleted everything and started from scratch several times but to no avail. The WebAssist should spend attention on this issue because the product has a problem and what I see is just the phrase "I have created a support ticket so Can we look into this issue further queries.
To view and edit your support ticket, please log into your support history, "
If someone managed to solve the problem, please share with other users PowerGallery 2.0
The WebAssist should make and publish a correction in the download center for users.
thanks
gruant2000381341
i haven't been having that exact same issue, but one thats maybe related.
every now and then PG2 will create a new gallery on it's own named cache.
when it does that i am seeing errors in the addimage page.
it's only doing it every so often so i don't know how to recreate the error...i just keep deleting that cache gallery as it happens
biz295654WebAssist
Originally Said By: gruant2000381341
I saw that too today. It happened in Safari. I tried FF and it didn't cache on me.
biz295654WebAssist
This one still needs work, that is for sure.
Please WA, address for us. Too many problems.
Thanks.
biz295654WebAssist
I purchased a second license for PG after checking with Jason exactly what to do with my server set up and all is good. I do think Safari cache has an issue, but if using another browser for editing in the system, all is good. So this is what I did to make for my particular server, per Jason's patience.
On some servers the permissions for the gallery and webassist folders and
all files and folders underneath need to be set to 755, and the
webassist/caching/PG_CachedResize_Image.php file needs to be updated to
change line 14:
$retVal = is_dir($pathname) || @mkdir($pathname, 0777);
$retVal = is_dir($pathname) || @mkdir($pathname, 0755);
and line 360:
mkdir ($cachefolder,0777,true);
mkdir ($cachefolder,0755,true);
And the admin_gallery/common/properties.php file needs to be edited to
change:
$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
To:
'dir' => 0755,
'file' => 0755
Thank you Jason for explaining it for me so I can address. Very much appreciated.
PatriceWebAssist
I had to work thru this again today so grateful the help notes are saved.
But on wish list: Two versions of gallery... one for 777 and one for 755 to save this work around. I am sure my server isn't the only one that needs it.
Thanks again Jason for showing me how to get it done.
biz295654WebAssist
Same thing here. Installed new today. Went thru the Server Error and 755 resets on properties.php. Partial fix.
Upon first uploading images, can edit.
Upon return, Your gallery has no images. I can see a preview if I select a gallery and "choose design" the preview is ok.
Back to gallery, edit images, no joy.
Using the "add to site" and Use this URL when linking to your PowerGallery from any web page: The requested URL /PG200/galleries/6/index.php was not found on this server.
So somethin' wrong. :-)
