Problems with Info window
Thread began 10/26/2011 5:41 pm by badsusmc429990 | Last modified 10/27/2011 9:19 am by Jason Byrnes | 1237 views | 1 replies |
badsusmc429990
Hello i am using your Pro maps for google wizard to add my custom content to my info windows. i added the facebook like fucntion to the code but it will actually only show up every once in a while. i am using the Standard HTML 5 format for the like button so it works properly When,If, it actually shows up. is there a way to make the page buffer and load correctly every time?
I have both tried adding this function inside and OUtside of the wizard by editing the Wagmap_1 file but the same problem persists. i even tried adding a test map to a seperate page so it didnt have to load anything but the map but i get the same issue. and Even if it does load. The info window box doesnt automaticly resize and alot of the time the text shows partialy inside the box and partially outside.
also as a side note if its possible. is it possible to add a generic custom info window layout. to have everything be the same for the new addresses that get added to the map except of course the address?
if requested i can show the code that has been used. this is for a major project on the site and is definatly something that needs to be fixed.
any help is greatly appriciated THX in advance
sincerly Dan
please post a link where i can see the problem to investigate the cause.
