Unknown Column on Confirm.php, fixes elsewhere in forum aren't working
Thread begun 11/09/2011 7:59 am by Justin@AdventDesign | Last modified 11/09/2011 12:03 pm by Jason Byrnes | 2803 views | 5 replies |
Justin@AdventDesign
When attempting to checkout from the confirm.php page, I get the following error:
Unknown column 'M00122' in 'field list'
The order is inserted into the 'orders' table properly, but nothing shows up in the orderdetails table.
I've found similar events in numerous posts throughout this forum.
'M00122' is the part number of the product in the cart, so first I changed the DetailProductID in the orderdetails table to varchar rather than INT, which appears to be the fix for most. Still get the same error after this change. Dumped cache and sessions and tried a new browser, same error.
As suggested in another thread, on the confirm.php code I changed:
$WA_editCmd = mysql_query($WA_sql, $WA_connection) or die(mysql_error());
$WA_editCmd = mysql_query($WA_sql, $WA_connection) or die(mysql_error()."<br />".$WA_sql);
Then, rerunning the pages, I get:
Notice: Undefined variable: WA_sql in /Applications/XAMPP/xamppfiles/htdocs/beta/00_Aveo/confirm.php on line 292
Query was empty
I also tried modifying the ecart Object column for ID from number to text, thinking maybe that was the problem. Didn't work so I changed it back.
You can access and test the pages yourself at products/
I've attached the confirm.php page if that helps.
is M00122 the product ID stored in the ID column of the cart?
if so, then you need to change the data type for the DetailProductID column of the details table to varchar, and edit the Store order details behavior to pass that column as text.
Justin@AdventDesign
As mentioned above, I already fixed the DetailProductID with varchar. Can you give me a little more of a hint, is it off the confirm.php page I'd find the "Store order details" behavior? I'm not seeing it.
yes, the eCart Store Order Details behavior is on the confirm page.
just changing the column in the database will not fix the problem.
you need to edit the eCart Store Order details server behavior to change the data type being used to pass the value to the database.
Justin@AdventDesign
I believe this is the section of code I'm looking for, but there is nothing in the "Server Behaviors" pallet that sounds like anything remotely like that. Is that what I'm looking for?
// WA eCart Store Cart Details in Db
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection = $adventcms;
$WA_table = "orderdetails";
$WA_redirectURL = "checkout_success.php";
$WA_indexField = "DetailOrderID";
$WA_fieldNamesStr = "DetailOrderID|DetailProductID|DetailName|DetailPrice|DetailQuantity";
$WA_fieldValuesStr = WA_eCDB_ConvertNumber("".((isset($_SESSION["eCart1_OrderID"]))?$_SESSION["eCart1_OrderID"]:"") ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->DisplayInfo("ID") ."") . "|" . "".$eCart1->DisplayInfo("Name") ."" . "|" . WA_eCDB_ConvertNumber("".$eCart1->DisplayInfo("Price") ."") . "|" . WA_eCDB_ConvertNumber("".$eCart1->DisplayInfo("Quantity") ."");
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|none,none,NULL|none,none,NULL";
$WA_sql = "";
mysql_select_db($database_adventcms, $WA_connection);
$indexFieldIndex = -1;
if ($WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?', $WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
for ($i = 0; $i < sizeof($WA_fieldNames); $i++)
if ($WA_indexField == $WA_fieldNames[$i])
$indexFieldIndex = $i;
break;
$deleteFieldValue = $WA_fieldValues[$indexFieldIndex];
if (isset($deleteFieldValue) && $deleteFieldValue != "")
$deleteParamsObj = WA_generateInsertParams(array($WA_indexField), array($WA_columns[$indexFieldIndex]), array($deleteFieldValue), -1);
$WA_sql = "Delete from " . $WA_table . " where " . $WA_indexField . " = " . $deleteParamsObj->WA_dbValues;
$WA_okToDelete = false;
$eCart1->MoveFirst();
while (!$eCart1->EOF())
$insertParamsObj = WA_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_sql = "insert into ".$WA_table." (".$insertParamsObj->WA_tableValues.") values (".$insertParamsObj->WA_dbValues.")";
$eCart1->MoveNext();
if ($WA_redirectURL != "") {
header("Location: ".$WA_redirectURL); exit;
