Pear Issue
Thread begun 11/09/2011 7:59 pm by goat200487425014 | Last modified 11/11/2011 3:43 pm by goat200487425014 | 5174 views | 10 replies |
goat200487425014
Pear Issue
When I click send on my forgotpassword page, I get the please wait on my pae for about 1 minute then it gives the error in the screenshot below.
add the following code to line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
goat200487425014
I still get the same results with no errors displaying.
the path to pear you entered does not look correct:
../pear/php/
this should be a system path to the pear package, not a relative path.
you will need to contact the host for the correct path to pear.
goat200487425014
Well that takes me to the Mail.php file that the forgotpassword page is looking for correct?
the Path to Pear you enter should take you to the Mail.php file, yes. But it should be a system path, not a relative path.
on my system the path is:
/usr/local/share/pear/
I have no idea what that path should be for your system though. You will need to contact your host for that information.
also, to send an email through Googles servers, you need to connect to the Google smtp server using SSL.
in the email password behavior, use the following for the smtp server:
ssl://smtp.gmail.com
goat200487425014
ok I have contacted Dreamhost and verified that the path was /home/goatpj/pear/pear/
However, I am still getting the following errors....
Warning: require_once(/home/goatpj/pear/pear/Mail.php) [function.require-once]: failed to open stream: Not a directory in /home/goatpj/luckielosers.com/webassist/security_assist/mail_php.php on line 78
Fatal error: require_once() [function.require]: Failed opening required '/home/goatpj/pear/pear/Mail.php' (include_path='.:/usr/local/lib/php:/usr/local/php5/lib/pear') in /home/goatpj/luckielosers.com/webassist/security_assist/mail_php.php on line 78
that either means that the path to pear:
is not correct, or they do not have the Pear Mail package installed.
goat200487425014
I don't know what else to do with this, this is the path that dreamhost is telling me to use.
Everything that I need, do you see it in the screenshot?
that screen shot is of the pear/php directory
maybe instead of:
it should be:
/home/goatpj/pear/php/
i dont know.
