Step 3 Install Error
Thread begun 11/15/2011 3:10 am by paul283230 | Last modified 11/16/2011 1:24 am by paul283230 | 1681 views | 2 replies |
paul283230
I am trying to install powercms on a local server XAMMP had same message on Wampserver
Failed on Curl Fixed that
Then I came to Step 3
The database info is greyed out with
You have already completed this step.
when you click on next
ERROR: All fields are required.
Database Information
The only thing I can think is the root has no password
Checked the PHP files database info is correct name root password is empty
Can somebody tell how do you get it to install with a blank root password please
it will not install with a blank root password.
see this page for details on setting a root password in mamp:
faq.html#q9
paul283230
Jason,
Thanks for getting back to me
PowerCms is now installed on LocalHost using XAMPP
Must addmit the time I have took to install this extension I could have built the backend myself
For people like me who haven't got a clue about setting up a Localhost using PowerCMS with XAMPP
You can check your Server Security by opening Browser and typing in
index.php
Settings I had to change:
Tip when installing XAPP install to Example: C:\XAMPP
as c:\program files\XAMPP has some file restrictions
Step 1 ( Setup CURL )
Locate XAMPP install directory
2. open php/php.ini (probably C:\xampp\php\php.ini
or C:\ program files\apachefriends\xampp\php\php.ini)
3. do a search for the word ‘curl’ and uncomment (remove the leading semicolon) that line
before removing ;extension=php_curl.dll
after removing: extension=php_curl.dll
4. save & close
5. open apache/bin/php.ini (probably C:\xampp\apache\php.ini
or C:\ program files\apachefriends\xampp\apache\php.ini)
6. search for curl, uncomment as before (step 3)
7. save & close
8. Do not forget! restart apache
Step 2 (Reset XAMPP MySQL root password through SQL update:)
1.Start the Apache Server and MySQL instances from the XAMPP control panel.
2.After the server started, open any web browser and give phpmyadmin/ (if you are
running XAMPP on 8090 port). This will open the phpMyAdmin interface. Using this interface we can manager the
MySQL server from the web browser.
3.In the phpMyAdmin window, select SQL tab from the right panel. This will open the SQL tab where we can run
the SQL queries.
4.Now type the following query in the textarea and click Go
UPDATE mysql.user SET Password=PASSWORD('password') WHERE User='root';
FLUSH PRIVILEGES;
5.Now you will see a message saying that the query has been executed successfully.
6.If you refresh the page, you will be getting a error message. This is because the phpMyAdmin configuration
file is not aware of our newly set root passoword. To do this we have to modify the phpMyAdmin config file.
7.Open the file [XAMPP Installation Path] / phpmyadmin / config.inc.php in your favorite text editor.
8.Search for the string $cfg['Servers'][$i]['password'] = ”; and change it to like this, $cfg['Servers']
[$i]['password'] = ‘password’; Here the ‘password’ is what we set to the ‘root’ user using the SQL query.
9.Now all set to go. Save the config.inc.php file and restart the XAMPP server.
