blue_sky_music datasource
Thread began 7/15/2009 3:43 am by jenkolaka19379118 | Last modified 7/20/2009 1:46 pm by anonymous | 2761 views | 5 replies |
jenkolaka19379118
I just wanted to find out if the eCart blue_sky_music database was the same as the dataAssist blue_sky_music database?
I was following the ecart tutorial using the sample store site and the dataassist database and i ram into a mysql error about the mmServerScripts. I am not sure what triggered this.
I'm not sure if they are the same exact version... it depends on your dataassist and ecart version, but they were built based on the same structure so they will be very close to identical if they aren't exactly.
jenkolaka19379118
hi Ray,
When i copy the blue sky sample ecart store to my computer, it locks all the files in dreaweaver cs3. I am not sure how to unlock the whole site, and it keeps cuasing errors. Is there something I should be doing to the downloaded file before I use it as a sample website?
It shouldn't lock them. Must be the read-only attribute. You should be able to right click on the folder and set that for alll the contents.
jenkolaka19379118
Thanks Ray,
Thats all it was, the files were read-only when I downloaded them, but I have rectified the issue.
anonymous
Ray,
You've probably forgotten but I brought this up before. The eCart GSG database is different than the Powerstore database. I'm assuming those are the two "blue sky" databases that Jenko is referring to. They aren't hugely different but enough to cause errors.
