Captcha Clarity
Is there any way to make the Captcha Security Code a tad clearer? Often it's impossible to tell the letters written there. Any way to make them a bit more legible?
In Form Builder, click the Customize CSS Button.
From the initial select list, select Form Elements, in the secondary select list, select Captcha, this will bring up the editor to change all aspects of the captcha image.
Yes. It works. I was able to soften the noise and the color of the grid and now the characters are more legible.
Thank you.
I am also have a problem with the captcha code very difficult to read. However, when I get to the secondary select list to edit the captcha security, the edit button is greyed out and will not work. How can I make it active?
I'm not sure i follow, can you send a screen shot showing the problem in a zip archive.
in FB "Edit Group Contents" "Line 1, Set 1, Security Code" highlighted, in the "Type" row below that, the edit icon is not available. Clicking on the edit icon will not do anything. I am using windows 7 and dreamweaver Cs5. I cannot get into edt the Captcha security settings.
I see, the problem is that you are editing the form contents, not the form design.
to change the look of the captcha, you need to use the edit Design interface. not the edit contents interface.
In the initial window that opens for the form builder wizard, there is the Customize CSS button in the Choose a design section, you need to click that button top open the From design editor to change the look of the captcha image.
I can't change the clarity of the Captcha at all. The font types is changable but amount of clarity remains the same whatever one choose in the capthcha settings!? Also I have another question: I have built my login/logout/register set with SA and I have now learned that the SA wizard generated pages cant easily be modified in Form Builder!? That is not what I expected but I know this is a fact by now!? How am I gonna change the Captcha settings in the SA generated pages for example if I can't use FB to work the SA pages!??
Hello Jason,
I cannot find the support ticket created for this specific issue on my support history page. Is there another link for it?
Thank you!
