If else statement
Thread begun 12/19/2011 11:13 am by chuck429411 | Last modified 12/21/2011 10:58 am by chuck429411 | 1614 views | 2 replies |
chuck429411
If else statement
Hey Jason, my confirm.php page has a price column which is not displaying the case price if I order a case. I am guessing that I need an if else statement? Here's the existing code:
<?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->DisplayInfo("Price")); ?>
I need a statement along the lines of:
if Quantity is equal to CaseBreak, then DisplayInfo("CasePrice")
else DisplayInfo("Price")
can you help?
in your other thread, i had had you create a calculation for truePrice, the job of this calculation is to determine whether Price or CasePrice should be used.
instead of showing the price column:
you should be using the truePrice calculation:
<?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->DisplayInfo("truePrice")); ?>
chuck429411
That worked perfectly. Once again, thank you very much.
