file upload with apostrophe in filename
Thread begun 1/05/2012 1:53 pm by contact318852 | Last modified 1/12/2012 6:35 am by Jason Byrnes | 12371 views | 9 replies |
contact318852
Hoping for some guidance here if anyone can assist.
I have a form for applications, applicants fill the form, and upload a resume. I also have a backend administration area where human resources can view the applications and make notes on each one.
An unforeseen issue has popped up recently where applicants will upload a resume and include an apostrophe in the file name as in - john doe's resume.pdf -
Somewhere in the process the actual file name gets re-written to john doe\'s resume.pdf and as such the backend admin area can not find the link to that particular file.
As I understand it this addition of the forward slash is a security feature. My question is how can I and where can I alter the code to just have an apostrophe truncated so the file is rewritten as john does resume.pdf with no apostrophe and no forward slash?
cheers
Ian S
I assume you are using Data Assist to insert the file name into a database field?
What binding are you assigning to the field that contains the file name?
Cheers
Ian
contact318852
Hi the only Binding I have assigned is if file exists [NewFileName]_[Increment]
Ian S
Funnily enough, I have come across this exact same issue this morning!
I've put some client side validation in place to prevent the file being uploaded if it includes illegal characters.
Cheers
Ian
add the following code at line 1 of the page you have applied the upload to:
if(sizeof($_FILES) > 0) {
    foreach(
$_FILES as $k => $v) {
$_FILES[$k] = str_replace("'", "", $v);
contact318852
Hi Thank you,
That works in rewriting the database file name from johndoe's.pdf to johndoes.pdf but the actual filename is changed to johndoe\s.pdf and stored in the folder as that.
Should I change the bindings in the file manipulation upload wizard File upload from [FileName] to [Server File Name] ?
alright, I think the problem is caused by having the magic_quotes_gpc setting in your php.ini file enabled, this is a deprecated setting and should not be enabled on newer ph installation.
to work around the issue, try changing the code block i gave you earlier to:
    foreach(
$_FILES[$k] = str_replace(array("\\","'"), "", $v);
contact318852
Bingo! That did the trick works like a charm
your assistance is greatly appreciated.
Kerry
Ian S
Originally Said By: contact318852
  Hi Thank you,
Yes, you should bind to the Server File Name value for your Data Assist insert.
Cheers
Ian
Ian, in this case, Kerry is talking about the setting in the Upload File behavior for If the File Exists.
Not the binding in the data Assist insert record behavior.
in the insert record behavior, the server file name binding should be used, but do not change the If File Exists setting in the upload file behavior to use [Server File Name]. The If file exists setting is used to determine the server file name, so server file name cannot be used as a part of that setting, it would create circular logic.
