Help with HTML Editor and File Manage
Thread begun 1/20/2012 11:17 am by Surdej Web Solutions | Last modified 1/25/2012 8:34 am by Jason Byrnes | 2874 views | 7 replies |
I'm hoping someone can help me figure out what I am having problems with the file path for images when I insert them in the HTML Editor. When the image properties box opens, I click Browse Server and then select the image. When I select the image, I am taken back to the image properties box. I don't see a preview of the image and the file path is wrong.
It is showing: /home/user/public_html/images/uploads/filename.jpg
and it should be /images/uploads/filename.jpg
I have spent hours on this and I am losing a ton of time. I have re-installed and have had no luck. Any help would be greatly appreciated.
Thank you,
Jeff
send a copy of the webassist/kfm/configuration.php file please
Hi Jason,
It is attached. Thank you!
Jeff
this is a bit of a brute force fix, but change line 33:
$kfm_userfiles_output = rel2abs($kfm_userfiles_address,dirname(__FILE__));
$kfm_userfiles_output = str_replace("/home/user/public_html", "", rel2abs($kfm_userfiles_address,dirname(__FILE__)));
Jason,
That helped. The file path is correct but no preview in the image properties box and the image doesn't display in the editor or on the page.
Jeff
Laurent
Wrong Path to image
same issue here, the path retrieved by the file manager is a disk path (/var/www/vhosts/domaine.com/httpdocs/files/) instead of a URL path...
Regards
Laurent
