phpMyAdmin & recipes.sql
Thread begun 1/25/2012 9:27 am by nicesobhi2975262593 | Last modified 1/25/2012 12:25 pm by Jason Byrnes | 8433 views | 5 replies |
nicesobhi2975262593
hello
I'm new in php environment, when i used phpMyAdmin tool to import recipes.sql this error has appeared please help
Error
SQL query:
-- MySQL dump 9.11
-- Host: localhost Database: recipes
-- Server version 4.0.20a-debug
-- Table structure for table `accessgroups`
CREATE TABLE accessgroups(
AccessGroupID int( 11 ) NOT NULL AUTO_INCREMENT ,
AccessGroupName varchar( 50 ) default NULL ,
PRIMARY KEY ( AccessGroupID )
) TYPE = MYISAM ;
MySQL said: Documentation
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM' at line 15
what is the solution,please ?
in the sql file, change:
TYPE = MYISAM
ENGINE=MyISAM
nicesobhi2975262593
ENGINE=MyISAM
Thanks for fast help
but after wrote
ENGINE=MyISAM
SQL query:
-- MySQL dump 9.11
) ENGINE = MYISAM ;
#1046 - No database selected
SQL query:
-- Table structure for table `conferences`
CREATE TABLE conferences(
ConferenceID int( 11 ) NOT NULL AUTO_INCREMENT ,
ConferenceRoom int( 11 ) NOT NULL default '0',
ConferenceName varchar( 50 ) NOT NULL default '',
ConferenceDescription varchar( 50 ) NOT NULL default '',
ConferenceStarttimestamp( 14 ) NOT NULL ,
ConferenceDuration time NOT NULL default '00:00:00',
ConferenceBy varchar( 50 ) NOT NULL default '',
PRIMARY KEY ( ConferenceID ) ,
KEY ConferenceID( ConferenceID )
) ENGINE = MYISAM ;
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(14) NOT NULL,
Confer' at line 10
the recipes sql script will create tables in a database you have selected,
in php my admin, you need to have a database created and selected before running the sql script.
nicesobhi2975262593
Thnaks... But :(
i did it as you said i created database called" " then i imported the tables after changing you said then this message appeared
SQL query:
) ENGINE = MYISAM ;
Confer' at line 10
thanks for be patine i'm very new
are you copying the SQL into the phpMyAdmin window, or using the import tab?
you should be using the import tab
see the "How to import a MySQL (.SQL) file to your database" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
