upload not working
Thread began 7/22/2009 3:17 pm by geordie728 | Last modified 7/30/2009 11:41 am by Ray Borduin | 1288 views | 1 replies |
geordie728
upload not working
Using DFP 2.0.1
Here's my code for the upload
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images/products/thumbs/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
// WA_UploadResult2 Params Start
$WA_UploadResult2_Params = array();
// WA_UploadResult2_1 Start
$WA_UploadResult2_Params["WA_UploadResult2_1"] = array(
'UploadFolder' => "../images/products/large/",
// WA_UploadResult2_1 End
// WA_UploadResult2 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Insert_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "ProdThumb", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult1_Params);
WA_DFP_SetupUploadStatusStruct("WA_UploadResult2");
WA_DFP_UploadFiles("WA_UploadResult2", "ProdImage", "2", "[NewFileName]_[Increment]", "true", $WA_UploadResult2_Params);
and for the insert record
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connHCHQ;
$WA_table = "products";
$WA_sessionName = "WADA_Insert_products";
$WA_redirectURL = "products_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "ProdID";
$WA_fieldNamesStr = "ProdID|ProdBrandID|ProdName|ProdShortDesc|ProdLongDesc|ProdKeywords|ProdPrice|ProdRRP|ProdSKU|ProdThumb|ProdImage|ProdCatID|ProdSubCatID|ProdIsFeatured";
$WA_fieldValuesStr = "".((isset($_POST["ProdID"]))?$_POST["ProdID"]:"") ."" . "|" . "".((isset($_POST["ProdBrandID"]))?$_POST["ProdBrandID"]:"") ."" . "|" . "".((isset($_POST["ProdName"]))?$_POST["ProdName"]:"") ."" . "|" . "".((isset($_POST["ProdShortDesc"]))?$_POST["ProdShortDesc"]:"") ."" . "|" . "".((isset($_POST["ProdLongDesc"]))?$_POST["ProdLongDesc"]:"") ."" . "|" . "".((isset($_POST["ProdKeywords"]))?$_POST["ProdKeywords"]:"") ."" . "|" . "".((isset($_POST["ProdPrice"]))?$_POST["ProdPrice"]:"") ."" . "|" . "".((isset($_POST["ProdRRP"]))?$_POST["ProdRRP"]:"") ."" . "|" . "".((isset($_POST["ProdSKU"]))?$_POST["ProdSKU"]:"") ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."" . "|" . "".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."" . "|" . "".((isset($_POST["ProdCatID"]))?$_POST["ProdCatID"]:"") ."" . "|" . "".((isset($_POST["ProdSubCatID"]))?$_POST["ProdSubCatID"]:"") ."" . "|" . "".((isset($_POST["ProdIsFeatured"]))?$_POST["ProdIsFeatured"]:"") ."";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL";
$WA_connectionDB = $database_connHCHQ;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
was working previously and now it's not. Followed the tutorial to the letter.
any ideas?
What part isn't working? Is the file uploaded? are any fields updated? Do you get an error?
