Edit menu made in Site Assist Pro
Thread begun 7/23/2009 12:15 am by publisher384078 | Last modified 7/23/2009 9:12 am by publisher384078 | 3688 views | 4 replies |
publisher384078
I've created a site using SA Pro, but I need to edit the menu. I have SA Pro, CSS Menu Writer and more, I cannot get the edit dialog to come up in my DW properties panel. I've very new to Site Assist ( second project ). There has got to be a way to edit the menus made with SA Pro !!!!!!!!!!!!!!
What version of SA Pro and what version of Menu writer do you have? Make sure you have the latest version of both and you shouldn't have this problem.
There was a bug in an earlier verison of SA Pro that caused this problem, but it should be resolved in the latest builds.
publisher384078
Running latest version
I believe I am running the latest versions:
Palette Picker 1.0.4
(Google)Tools for 2.0.3
Surveyor 1.0.4
Site Assist 1.0.5
CSS Menu 2.0.1
Eric Myers 2.0.3
I've been getting some Java Script errors as well, when trying to access different CSS Menu options. When I get caught up with my work and have some time, I'll reinstall everything. Love the software, wish I had more time to really get to know it, I hate learning on the fly.
Those look like the latest versions.... did you build the site with previous versions? Maybe try updating and see if it updates the menu. You could maybe try generating the site again in a new directory and see if that menu is editable. If so I can show you how to update so your other one is too from that copy.
If it continues to not work, you will have to submit a support incident so somebody can debug it further with you.
publisher384078
Work Around
I started building the site yesterday, and realized I needed to change something after I'd already customized the background graphics etc. so rebuilding the site would have been a serious setback. I just went into the CSS sheets and edited some of it there, then I went into the templates and completed the corrections. It really was pretty simple, I spent more time screwing around trying to make the programs work! BUT, the customer hasn't approved it yet so I may need to make additional changes later.
