PowerStore 4.5 Menu
So, there is no way to move the "About Us" menu from the "Contact Us" sub-menu and put on the Main Menu?
If not, doesn't seem like a very flexible solution.
you can move the contact us menu item by editing the webassist/plugins/main_menu/menu.php file and changing:
<li class="parent top"><span><a href="../../../contactus.php">Contact Us</a></span>
<ul class="level-1">
<li><a href="../../../aboutus.php">About Us</a></li>
</ul>
</li>
<li class="parent top"><span><a href="../../../contactus.php">Contact Us</a></span></li>
Where would I change the Footer page name? (Return Policy, Privacy, etc)?
What does this error mean when I'm trying to browse the server to add a picture:
Warning: mkdir() [function.mkdir]: Permission denied in /homepages/20/d184490718/htdocs/BlondeBombShellK/webassist/kfm/initialise.php on line 153
error: "" could not be created
In the power store content management system, Under the footer pages section, select the Content group you want to rename.
click the edit button next to Content and type the new name for the content location, then click updated.
next click the edit button for the header, and select the content area name then update again.
in the wa_settings table of the power store database, what is the Image Upload Folder set to?
it should be set to imagesupload/
