Changing Foreign Key from numeric to text. Now search does not work
Thread begun 3/09/2012 8:13 am by John Langer | Last modified 3/09/2012 10:54 am by Jason Byrnes | 2098 views | 5 replies |
John LangerBeta Tester
I created an admin section some time ago using the data assist wizard and it works very well. Now my client requires (for reasons involving a third party) that a foreign key used, is changed from a numeric ID (INT), to a text field (VarChar). I've done this and the basic insert, update and display works fine but the search does not. I have the search form on the results page as well as the normal separate file (I've attached them both). This particular search field (Region) is using a dynamic drop down menu.
The field involved is FKeventsRegionID. It used to be 1, 2, 3 etc but is now "England: South East", "England: East" etc
There is obviously something I've missed here but for the life of me it escapes me. Can you help please?
If you go here you will see a search on the right using a drop down. This works fine. This site is still using the old code but on my testing server it works fine.
Any help appreciated.
if you view source of the search form, the value of the region seelct list is stil using the numeric values, not the strings:
<select name="region" class="dropBox">
<option value="">All</option>
<option value="1">England: East</option>
<option value="2">England: East Midlands</option>
<option value="3">England: London</option>
<option value="4">England: North East</option>
<option value="5">England: North West</option>
<option value="6">England: South East</option>
<option value="7">England: South West</option>
<option value="8">England: West Midlands</option>
<option value="9">England: Yorkshire and the Humber</option>
<option value="21">National</option>
<option value="10">Northern Ireland</option>
<option value="11">Scotland: Central</option>
<option value="12">Scotland: Highlands and Islands</option>
<option value="13">Scotland: North East</option>
<option value="14">Scotland: South East</option>
<option value="15">Scotland: South West</option>
<option value="16">Scotland: West</option>
<option value="17">Wales: Mid</option>
<option value="18">Wales: North</option>
<option value="19">Wales: South East</option>
<option value="20">Wales: South West</option>
</select>
you will need to edit the select list so that the value uses the same column as the label.
Hi Jason,
Thanks for the reply. The view source isn't really a true reflection. I haven't changed anything on the live site so it would show numeric options. On my testing server it shows the following
html:
<td>
<option value="England: East">England: East</option>
<option value="England: East Midlands">England: East Midlands</option>
<option value="England: London">England: London</option>
<option value="England: North East">England: North East</option>
<option value="England: North West">England: North West</option>
<option value="England: South East">England: South East</option>
<option value="England: South West">England: South West</option>
<option value="England: West Midlands">England: West Midlands</option>
<option value="England: Yorkshire and the Humber">England: Yorkshire and the Humber</option>
<option value="National">National</option>
<option value="Northern Ireland">Northern Ireland</option>
<option value="Scotland: Central">Scotland: Central</option>
<option value="Scotland: Highlands and I">Scotland: Highlands and Islands</option>
<option value="Scotland: North East">Scotland: North East</option>
<option value="Scotland: South East">Scotland: South East</option>
<option value="Scotland: South West">Scotland: South West</option>
<option value="Scotland: West">Scotland: West</option>
<option value="Wales: Mid">Wales: Mid</option>
<option value="Wales: North">Wales: North</option>
<option value="Wales: South East">Wales: South East</option>
<option value="Wales: South West">Wales: South West</option>
</select>
</td>
I was merely trying to point out that a "similar" search worked on my testing server with the new text "options" or text ID's in the database.
I've just tried the same exercise on the search page of my admin section (on my testing server) and this is showing the correct options
html:
<th class="WADADataTableHeader">Region:</th>
<td class="WADADataTableCell">
<select name="S_FKeventsRegionID" id="S_FKeventsRegionID">
</select>
</td>
I hope that clarifies things a bit better. Sorry if I mislead you before.
in the data assist search behavior the column type for the FKeventsRegionID column is set to Numeric, you will need to change that to set the column type to text.
Thanks jason, that did it.
Obvious really. Doh! :)
glad to hear it is working.
