Help needed with dynamic link
Thread begun 3/10/2012 6:45 pm by sjones435326 | Last modified 3/12/2012 9:20 am by Jason Byrnes | 3485 views | 7 replies |
sjones435326
I have a Customer I’m working for that would like “dated notes” for different tables.
I have created the two tables - COMPANIES - COMPANY_NOTES
the relational field is “customer_id”
The primary key for COMPANIES is customer_id
The primary key for COMPANY_NOTES is note_id (but it also contains customer_id)
I have used the DataAssist Wizard to create all of the pages for both tables
I wanted to just have a hyperlink from the companies_Detail.php that would use a dynamic hyperlink with the S_customer_id
company_notes_Results.php?S_customer_id= <?php echo $row_WADAcompanies['customer_id']; ?>
However that is not working because of the x.Search and y.Search variables it is expecting a URL like this “company_notes_Results.php?S_customer_id=5&Search.x=33&Search.y=4&Search=Search”
And some companies are going to have multiple notes on their account.
Does anyone have any suggestions to achieve a dated note system or can you help me correct the mess that I’m in now. Maybe I’m going about this wrong any suggestions would be appreciated.
you only need to add the static variables along with the dynamic:
company_notes_Results.php?S_customer_id=<?php echo $row_WADAcompanies['customer_id']; ?>&Search.x=33&Search.y=4&Search=Search
sjones435326
Jason, each search returns different values for the Search.x and Search.y example
company_notes_Results.php?S_customer_id=22&Search.x=42&Search.y=16&Search=Search
company_notes_Results.php?S_customer_id=5&Search.x=52&Search.y=11&Search=Search
I have the S_customer_id as dynamic but I don't know what the values of Search.x and Search.y are?
Now I have tested the URL just changing the S_customer_id and leaving the old values for Search.x and Search.y and it did not seem to affect the returned results by leaving those values.
Do the Values of Search.x and Search.y matter at all? or can I just type in any values?
the values of search.x and search.y dont matter, they are the x and y coordinates of where the mouse clicked the submit button image.
can you send a copy of the company_notes_Results.php page so i can look at the code.
sjones435326
Jason, where do you want me to send it to. When I try to post it I get the following error
The text that you have entered is too long (20639 characters). Please shorten it to 10000 characters long.
I'm new the the WebAssist family and not sure about where you want me to send it?
compress the php file to a zip archive and attach the zip file please.
sjones435326
Jason, I attached the zip file
