Please Wait loading...
Thread began 4/24/2012 7:55 am by jon392819 | Last modified 4/25/2012 9:41 am by Jason Byrnes | 1253 views | 3 replies |
jon392819
Hi Guys,
I have the above message when I click browse server. It just sits there. No thumnails display.
Files are on a shared host that I have not used before.
PHP info shows GD is enabled
Changed get.php to new filename and did the find replace. No joy.
Changed the javascript in the index.php as suggested in the other posts. Again, no joy.
Any suggestions welcome....
Jon
What version of PHP is your host running? The file manager requires PHP 5.2.3 or greater.
If your host is running PHP 5.2.3 or greater and you are still having this issue, I will start a support incident to look into the problem further.
jon392819
Hi Jason, its 5.2.17. Problem persists. Can you create a ticket.
Many thanks Jason. Skype is format.ie if this helps.
Jon
