contact form not sending checkbox
Thread begun 5/02/2012 3:48 am by shanebrough438709 | Last modified 3/05/2015 11:49 am by Jason Byrnes | 14478 views | 15 replies |
shanebrough438709
Hi im having a problem with a website im building and testing.
in the contact form when i fill out the form and check some of the checkboxes, i recieve a email with the form info but the check boxes are empty.
can anyone help??
Also just discovered my selectable dropdown menu is only sending 1 of the selected items
Thanks in advance
html code:
<th>Membership * </th>
<td>
<input type="checkbox" name="membership[]" value="ecssa">ECSSA<br />
<input type="checkbox" name="membership[]" value="psa">PSA<br />
<input type="checkbox" name="membership[]" value="nsai">NSAI<br />
<input type="checkbox" name="membership[]" value="eqa">EQA<br />
<input type="checkbox" name="membership[]" value="Other">
Others (Fill Below) <br />
</td></tr>
contact php:
$field_name = $_POST['cf_name'];
$field_phone = $_POST['cf_phone'];
$field_mobile = $_POST['cf_mobile'];
$field_email = $_POST['cf_email'];
$field_company = $_POST['cf_company'];
$field_services = $_POST['services[]'];
$field_other = $_POST['cf_other'];
$field_areas = $_POST['cf_areas'];
$field_membership = $_POST['membership[]'];
$field_othermember = $_POST['cf_othermember'];
$field_job = $_POST['cf_job'];
$field_leads = $_POST['leads[]'];
$field_agree = $_POST['agree[]'];
$mail_to = 'Removed';
$subject = 'Message from a site visitor '.$field_name;
$body_message = 'From: '.$field_name."\n";
$body_message .= 'E-mail: '.$field_email."\n";
$body_message .= 'Phone Number: '.$field_phone;
$body_message .= 'Mobile: '.$field_mobile;
$body_message .= 'Company Name: '.$field_company;
$body_message .= 'Services offered: '.$field_services;
$body_message .= 'Other Services: '.$field_other;
$body_message .= 'Areas will Work: '.$field_areas;
$body_message .= 'Membera of: '.$field_membership;
$body_message .= 'Other Membership: '.$field_othermember;
$body_message .= 'Job Min Value: '.$field_job;
$body_message .= 'Recieve leads: '.$field_leads;
$body_message .= 'Agree to terms: '.$field_agree;
$body = "From: $name_field\n E-Mail: $email_field\n Message:\n $message\n $check_msg";
$headers = 'From: '.$field_email."\r\n";
$headers .= 'Reply-To: '.$field_email."\r\n";
$mail_status = mail($mail_to, $subject, $body_message, $headers);
if ($mail_status) { ?>
<script language="javascript" type="text/javascript">
alert('Thank you for the message. We will contact you shortly.');
window.location = 'index.html';
</script>
else { ?>
alert('Message failed. Please, send an email to removed');
</script>
multile checkboxes and multiple select lists pass the values as an array. you need to convert the array to a string, add this code at line 1 to convert the array to a comma seperated list:
if($_SERVER["REQUEST_METHOD"] == "POST")     {
    foreach(
$_POST as $key => $val) {
        if(
is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
you will also need to change these lines:
to remove the [] from the element names:
$field_services = $_POST['services'];
$field_membership = $_POST['membership'];
$field_leads = $_POST['leads'];
$field_agree = $_POST['agree'];
the [] needs to be included with the name of the element in the form, but not when referring to it in the POST array.
if you need further assistance, compress a copy of the file into a zip archive and include that with your replay so i can see the entire page code in context.
shanebrough438709
Hi Jason, Thanks for reply
Tried what you suggested but ended up getting other line errors example:
Parse error: parse error in \\nas01\nas\k\e\keepusafesecurity.net\web\site1\contact3.php on line 52
As you can prob tell am new to this!!
Any help appreciated zip file attached
i'll need a copy of the contact3.php page.
please dont save it as a text file, just compress the original zip file into a zip archive. leave it as is, in the original form unchanged,
shanebrough438709
Find attached cheers!!
at line 7, the php code block is closed, but you have more php code after it:
change line 7 and 8:
$field_name
so that a new code block is created.
shanebrough438709
Thanks Jason worked perfectly.
any ideas on the selective drop down menu??
only sends back the last highlighted option rather than all that is selected
cheers
shane
send me all of your pages, the form page and the email script i n a zip archive.
what is the name of the select list?
shanebrough438709
Hi Jason please find attached the zip file:
contains: contractors htm and contact3 php
The form in in the contractors page and the name of the list is 'cf_areas'
cheers
also if you could pm me would be great have something to ask you.
for a multiple select list to pass multiple values, the name needs to have [] added to the end.
change:
<select multiple="multiple" name="cf_areas">
<select multiple="multiple" name="cf_areas[]">
