Issue installing 1.0.4
Thread begun 5/02/2012 2:03 pm by sales435980 | Last modified 5/03/2012 7:02 am by Jason Byrnes | 1410 views | 2 replies |
sales435980
Hi I have downloaded 1.0.4 and deleated 1.0.2 that I had installed.
The issue that I have is that when I go to install 1.0.4 I get and error saying the extention can not be installed as it requires dreamweaver 9 or later.
I have CS5 Version 11
I have attached images
sales435980
Additional issue
I am now also getting an error on launching CS5
Image attached
when downloading the extension, make sure to select the option to Save it to your computer. You may have a choice to open it or save it, always choose the save option.
The error you are reporting usually happens if multiple versions of dreamweaver are installed and you double click the downloaded MXP file to start the installation.
Instead, start the installation manually after the extension is downloaded.
Open the Extension manager, then click the install button and select the MXP File you downloaded to begin the install.
for the error:
in dreamweaver go to Window -> Workspace -> Reset '<your layout name>' to reset the workspace, then Delete the Dreamweaver Cache file from the users configuration folder:
