Australian post code validation
Thread begun 5/10/2012 4:43 am by CraigR | Last modified 3/27/2014 12:24 pm by Jason Byrnes | 7029 views | 6 replies |
CraigRBeta Tester
Australian (& New Zealand) post code validation
On my checkout form, I have zip code server validation set to allow 5 & 9 digit US, 6 digit canadian and UK post code, however a potential Australian customer was recently unable to check out as the 4 digit aussie postcode was not permitted.
Doesn't appear as an option in the server behavior interface, is there a way to enable this without allowing for blank entry ?
I had a play with the validation function (as below) adding $anz as an extra parameter, but still can't get it to work
function WAValidateZCNew($value,$us5,$us9,$can6,$uk,$anz,$required,$number)  {
$WAFV_ErrorMessage = "";
$isValid = true;
$allowed = "() -.\n\r";
$charVal = "";
if (!(!$required && $value=="")) {
$newVal = "";
$hasLetters = false;
for ($x=0; $x < strlen($value); $x++) {
$z = substr($value, $x, 1);
if (($z >= "0") && ($z <= "9")) {
$newVal .= $z;
$charVal .= "N";
else if (($uk || $can6) && ((($z >= "a") && ($z <= "z")) || (($z >= "A") && ($z <= "Z")))) {
$charVal .= "A";
$hasLetters = true;
else if (strpos($allowed, $z) < 0 || $x == 0 || $x == strlen($value)-1) {
$isValid = false;
$acceptPattern = ",";
if ($anz) {
$acceptPattern .= "NNNN,";
if ($us5) {
$acceptPattern .= "NNNNN,";
if ($us9) {
$acceptPattern .= "NNNNNNNNN,";
if ($uk) {
$acceptPattern .= "ANNAA,ANNNAA,AANNAA,AANNNAA,ANANAA,AANANAA,";
if ($can6) {
$acceptPattern .= "ANANAN,";
if (strpos($acceptPattern,",".$charVal.",") === false)
$isValid = false;
if ($isValid && !$hasLetters && ($us5 || $us9 || $anz)) {
if ($anz) {
$isValid = preg_match('/^\d{4}$/', $value);
if ($us5) {
$isValid = preg_match('/^\d{5}$/', $value);
if ($us9 && (($us5 && !$isValid) || !$us5)) {
$isValid = (preg_match('/^\d{5}[-\. ]\d{4}$/', $value) || preg_match('/^\d{9}$/', $value));
if (!$isValid) {
$WAFV_ErrorMessage .= ",".$number;
return $WAFV_ErrorMessage;
CraigRBeta Tester
Fixed - thanks Ray
Problem resolved through support call.
Here is the amended function which allows validation of AUS/NZ postcodes, which are all 4 digit I believe...
When calling the function, remember you will need an extra parameter
$isValid = true;
$charVal = "";
$newVal = "";
$newVal .= $z;
$charVal .= "N";
$charVal .= "A";
$hasLetters = true;
$isValid = false;
if ($anz) {
if ($us5) {
if ($us9) {
if ($uk) {
if ($can6) {
$isValid = false;
if ($anz) {
if ($us5 && !$isValid) {
if ($us9 && !$isValid) {
if (!$isValid) {
info185511
Four digit postal code validation for certain countries
After searching the forums, I came across the above code which I placed in the wavt_scripts_php.php
Unfortunately I am trying to figure the next step as the confirm.php shows the following
Warning: Missing argument 8 for WAValidateZC(), called in /Applications/MAMP/htdocs/NBA/confirm.php on line 30 and defined in /Applications/MAMP/htdocs/NBA/webassist/form_validations/wavt_scripts_php.php on line 897
Warning: Missing argument 8 for WAValidateZC(), called in /Applications/MAMP/htdocs/NBA/confirm.php on line 40 and defined in /Applications/MAMP/htdocs/NBA/webassist/form_validations/wavt_scripts_php.php on line 897
Warning: Missing argument 8 for WAValidateZC(), called in /Applications/MAMP/htdocs/NBA/confirm.php on line 42 and defined in /Applications/MAMP/htdocs/NBA/webassist/form_validations/wavt_scripts_php.php on line 897
the codes on line 30, line 40, line 42 are
$WAFV_Errors .= WAValidateZC(((isset($_POST["postcode"]))?$_POST["postcode"]:"") . "",true,true,true,true,true,9);
and the code on line 897 is
function WAValidateZC($value,$us5,$us9,$can6,$uk,$anz,$required,$number) {
the $anz would represent a four digit postal code correct
Client received an order from the Netherlands which the customer could not apply the postal code.
Any advice would be appreciated .
there are only 7 arguments in this code:
add an 8th:
$WAFV_Errors .= WAValidateZC(((isset($_POST["postcode"]))?$_POST["postcode"]:"") . "",true,true,true,true,true,true,9);
info185511
Followup
Thank you for your quick help much appreciated
you're welcome.
