Search by ProductID
Thread began 5/17/2012 9:44 am by mick106153 | Last modified 5/22/2012 8:17 am by Jason Byrnes | 1798 views | 3 replies |
mick106153
Search by ProductID
Using phpMyAdmin I can search MySQL in the ProductID field for a single product but can't figure out how to search for a range of ID's.
i.e. 501, 502, 303 etc.
I've tried various separators and operators to no avail.
How do I search for a string of disparate ID's
Mick
use either an OR separator, or the IN clause:
OR example:
SELECT * FROM products WHERE ProductID = 501 OR ProductID= 502 OR ProductID = 303
IN Example:
SELECT * FROM products WHERE ProductID IN (501, 502, 303)
mick106153
Thanks Jason
That works but how do I limit it to return only i.e. ProductName, ProductSKU etc within the chosen records?
Mick
in the select statement "*" means all columns.
to limit the columns that are returned, type the name of each column in the Select statement:
SELECT column1, column2, column3 FROM table
see the w3schools site for more details:
sql/
