Log in problem
Thread began 5/21/2012 7:11 am by bill3786 | Last modified 5/21/2012 2:18 pm by Jason Byrnes | 1818 views | 5 replies |
bill3786
Log in problem
The client's has requested the following system for the site.
Product prices are to be shown in sterling or euros. The product and detail pages have if/else statements controlling what prices are displayed depending on the users country at login.
The sterling prices (if) are shown if the users country is UK and euro prices (else) are shown if the users country is not UK. All UK customers pay through the site using Worldpay and all non-UK customers are not shown an add to cart button and are instructed to order by phone and pay by phone.
This system all works well in testing but has thrown up one problem as follows.
If a UK user logs in by opening the login page and has the "remember me" and "log me in automatically" ticked and then clicks login, the prices for all subsequent products are shown correctly in sterling.
However if a UK user logs in by opening the login page and has the "remember me" and "log me in automatically" ticked but doesnt actually click the login button and then uses the menu bar to see products with the login page still displayed, the prices for all subsequent products are displayed in euros.
Is there anything which can be done to eliminate this problem?
As a secondary question, what is the correct operation of the "log me in automatically" tickbox? If it has been previously ticked by a user should the login page be displayed on a subsequent login?
please send a copy of the login page.
bill3786
Attached login page.
login.zip
there are 2 authenticate user behaviors on your page.
the first is used when the the login button is pressed.
the second is used when the autologin option is selected.
In the first one, you have set the UserCountry session to be set, but in the second one, you have not.
you will need to edit the second behavior to set the user country session variable.
also, the second one does not have a success redirect set, this is why it doesn't appear that the login has worked, you should set a success redirect on the second authenticate user behavior.
bill3786
Ok, thanks. That has stopped euro prices showing incorrectly.
I have added the same redirect for both the login succeeds and login fails from the first authenticate behaviour to the second. Is this correct, you only mention the success direct?
Also the first behaviour had a User Validated =1 in the database tab, do I add this to the second behaviour?
the 2 instances of the authenticate user behavior should use al;l of the same settings, except for the trigger.
the trigger should be the only difference between the 2.
