Mutiple Addressess Not Showing
Thread begun 5/24/2012 9:10 am by kelly341459 | Last modified 5/25/2012 7:18 am by Jason Byrnes | 1478 views | 2 replies |
kelly341459
I am working on a map to show multiple locations. The map can be seen here: indexNEW.html
I have entered several locations, but the map is only showing one.
Any idea what I have done wrong? I have uploaded the full contents of the "webassist" folder and that folder has full read/write permissions.
Ian S
Hi
I am assuming that you are pulling this info from a database? Are you certain that the database is returning the correct number of addresses? Can you output them to the screen to be sure?
Cheers
Ian
This is a bug we have identified in Design Extender, we will be releasing an update early next week, this issue should be included in that update.
in the mean time, the fix is to edit the map JS file in the webassist/google_javascript folder.
do a search for :
'google_javascript/images/
and replace each instance with:
'webassist/google_javascript/images/
to update the marker image paths top the correct location.
