While executing onMouseUp in WA_AppBuilder.htm JavaScript error occured...
Thread begun 7/31/2009 9:16 am by beezodog304808 | Last modified 8/28/2009 8:15 am by CraigR | 4801 views | 10 replies |
beezodog304808
While using DataAssist this AM I got the following message after pushing the FINAL button:
"At line 4414 of file "Macintosh HD:Applications:Adobe Dreamweaver CS4:Configuration:Commands:WA_AppBuilder.js":The objects is not currently contained in a document."
Does anyone have an idea of what this means?
This looks like it may be a problem with the cache file. You should be able to delete this file from your user configuration area for your version of Dreamweaver. The paths to this location and more information about this can be found in this post:
showthread.php?t=1589
If you have any further problems with this let us know, there are some other things we can try.
CraigRBeta Tester
new to dataassist
I have finally succumbed and bought dataAssist, but am having problems already.
I get a similar error to the above.
I cleared the cache file as usual, but no better.
I also tried uninstalling then reinstalling the extension. (v 2.0.5)
Error message attached...
Grateful for any assistance.
CraigRBeta Tester
Has anyone else come across this problem?
It may just be another form of corruption that has occurred in your configuration folder. Here is a link to a thread that discuses renaming or deleting this to have DW recreate it. However this will uninstall your installed extensions. It is worth a try though.
showpost.php?p=12293&postcount=2
If this does not resolve the issue let us know and I will make sure a ticket is opened and you get to the correct people on this.
CraigRBeta Tester
Hi Eric,
I renamed the configuration folder.
Restarted then closed Dreamweaver to recreate it.
Opened extension manager (outside of DW)
Deleted all extensions
Reinstalled all extensions
Reactivated all extensions.
Same problem, however...
If I run through the wizard without changing anything, it sometimes completes without error.
The problems seems to stem from recordset paging, if i leave the column count to 1, it sometimes works, however if I change it to 2 or more, the wizard always crashes, with the same error, as posted above.
CraigRBeta Tester
sorry to raise this again, but after several further attempts i'm still unable to use this extension.
I have opened a ticket for you on this issue, please login to webassist.com and visit your support history to update the ticket. I have asked for some more details about other extensions that you have installed. Hopefully we will be able to get this worked out soon for you. I will update this thread when we reach a conclusion in the ticket.
CraigRBeta Tester
any news on this ticket ?
thanks
I have made a response to the ticket, please post back with the info so we can determine what to do next.
