Server Error
Thread begun 5/29/2012 9:11 am by Jordan | Last modified 6/03/2012 7:14 am by Jordan | 2541 views | 4 replies |
Jordan
Server Error
At the moment I am looking to create a page that has two results pages inserted as plugins onto one single page.
I converted WOW Slider into a dynamic slider using Data Assist from the new Data Bridge software and under it I need to show results for inserted blocks. I use this as a home page editing admin page.
The problem I get is when I insert the results pages into the same page as plugins I get a server error. When I only have one showing it's fine.
Is there a way to make these work that you know of?
Thanks.
please provide more details. What is the error you are sing?
try adding the following code at line 1 of your page:
error_reporting
(E_ALL);
Can you provide a link where i can see the problem?
Jordan
Thanks for getting back to me. I have attached a screenshot of the page I get when I have 2 results pages inserted as plugins.
The error I get after entering the code to the top of the page is:
Fatal error: Cannot redeclare class WA_AltClassIterator in /Users/jordantrainor/Sites/localhost/jordan_trainor/mieke_van_poll/upload/public_html/_admin/_plugins/homeblocks_results.php on line 110
I only have it on my localhost at the moment so I've not got it up and running anywhere at the moment.
Thanks again.
on both results page, there is the following code that defines WA_AltClassIterator class
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter = 0;
$this->ClassArray   = $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter = 0;
$this->ClassCounter++;
    if (
$this->ClassCounter > 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
change that to:
<?php if(!class_exists('WA_AltClassIterator')) { ?>
  var
$DisplayIndex;
  var
$DisplayArray;
  function
  function
    if (
      if (
$incrementClass) {
      if (
    if (
      return
    else
      return
this way it will only be defined once.
Jordan
Excellent, worked like a charm. thanks for the support.
