No Such file or directory
Thread begun 6/14/2012 10:26 am by gzirfas374932 | Last modified 6/15/2012 11:42 am by gzirfas374932 | 1899 views | 4 replies |
gzirfas374932
Godaddy moved my hosting from a single shared to their new one that shares resources. When they did this ALL my Web assist stuff stopped. (www.denucciconstructors.com)
They said it was errors in my scripts. Not believing them I took the CMS out and made the pages static. No problems. So I reuploaded the CMS and when I try to install (CMS/) it I get this:
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/70/4034770/tmp/sess_cp66iognvcmh9ok1gt3gvkrsm0, O_RDWR) failed: No such file or directory (2) in /home/content/70/4034770/html/CMS/install_cms/global.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/70/4034770/html/CMS/install_cms/global.php:2) in /home/content/70/4034770/html/CMS/install_cms/global.php on line 2
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/70/4034770/html/CMS/install_cms/global.php:2) in /home/content/70/4034770/html/CMS/install_cms/global.php on line 2
Warning: Cannot modify header information - headers already sent by (output started at /home/content/70/4034770/html/CMS/install_cms/global.php:2) in /home/content/70/4034770/html/CMS/install_cms/wizard.php on line 44
Warning: Unknown: open(/var/chroot/home/content/70/4034770/tmp/sess_cp66iognvcmh9ok1gt3gvkrsm0, O_RDWR) failed: No such file or directory (2) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct () in Unknown on line 0
Using UE or form toolkit results in similar errors
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/70/4034770/tmp/sess_cp66iognvcmh9ok1gt3gvkrsm0, O_RDWR) failed: No such file or directory (2) in /home/content/70/4034770/html/webassist/form_validations/wavt_validation.....etc
Is it possible their new server has a problem with web assist stuff? the site worked terrific before except it was slow as mud.
HELP, I need to fix the form and the cms fast.
the errors are caused by the session.save_path setting in the PHP.ini file.
you will need to have go daddy correct the session.save_path setting.
gzirfas374932
Path setting
So the path should be set to:
Is that correct?
or just
I cant answer that question for you, I don't know what paths are valid or not on your GoDaddy server.
you will need to contact Go Daddy for an answer to this question.
gzirfas374932
Thanks for the fast reply. I will hash it out with GoDaddy (thats GD for short, lol)
As always you guys are terrific.
G
