Whats wrong with this statement
Thread begun 6/22/2012 8:54 pm by akstudio | Last modified 8/28/2013 3:25 pm by tim299030 | 7906 views | 30 replies |
akstudio
if ($row_DetailRS1['isVideo'] == 1)
echo '<div id="video_player"></div>';
else
echo '<div class="large-img">
<img src="images/portfolio/<?php echo $row_DetailRS1["image-lg"]; ?>" width="936" alt="" />
</div>';
The output of <?php echo $row_DetailRS1["image-lg"]; ?> on the page looks like this:
I cannot see where the issue is. If I take that EXACT code and place it outside the if statement, it works perfect.
Everything works as intended except that line... ugh.
thanks.
CraigRBeta Tester
try putting the "image-lg" in single quotes
You have an echo nested in an echo...
It should be
else
<img src="images/portfolio/'.$row_DetailRS1["image-lg"].'" width="936" alt="" />
</div>';
tim299030
I want to do something similar but can't get mine to work. Basically, some of my books have downloadable excerpts and some do not.
I have created a custom field in the ps4_products database called ProductExcerpt. If the book has an excerpt, then the name of the excerpt is in the ProductExcerpt field. If there is no excerpt for a specific book, there is nothing in that field.
I want to make it so that if there is an excerpt, there will be a link to the the pdf showing "Read excerpt". If there is not an excerpt, I don't want anything to show.
if ($ProductExcerpt['ProductExcerpt'] = !"")
echo '<a href="https://mywebsite.com/excerpts/'.$ProductExcerpt['ProductExcerpt'].'.pdf">Read excerpt</a>';
else
echo '';
It seems simple but I just can't get it to work.
Thanks for any responses.
what is the recordset name?
when referring to a recordset result, you us:
$row_recordsetName['columnName']
as the reference.
tim299030
Ahhh... -- the recordset name is Recordset1 (forgot to name it).
So my statement now looks like this:
if ($row_Recordset1['ProductExcerpt'] = !"")
echo '<a href="https://mywebsite.com/excerpts/'.$row_Recordset1['ProductExcerpt'].'.pdf">Read excerpt</a>';
else
echo '';
So now when I hold my cursor over the link that is showing it gives me:
https://mywebsite.com/excerpts/1.pdf
INSTEAD I WANT IT TO BE
https://mywebsite.com/excerpts/0788026356.pdf
My recordset is:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_PowerStoreConnection, $PowerStoreConnection);
$query_Recordset1 = "SELECT ProductExcerpt FROM ps4_products";
$Recordset1 = mysql_query($query_Recordset1, $PowerStoreConnection) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
Thanks for your help.
that recordset will only return the first record. you will need to add a where clause to return the specific record you want.
tim299030
Okay -- hmm..., so I tried this:
SELECT ProductID, ProductExcerpt
FROM ps4_products
WHERE ProductID = %s
and it didn't work.
So how do I point to that specific record?
you need to insert the produce number
WHERE ProductID = 123
tim299030
But how do I do that dynamically? Can I put ['ProductID'] in the sequel statement?
FROM ps4_products
WHERE ProductID = ['ProductID']
Or do I need to create a variable for that? I'm not sure how to create a variable.
