upgrade to 4.5.3 not working
Thread begun 7/10/2012 9:10 am by zinlover320832 | Last modified 7/25/2012 10:34 am by Jason Byrnes | 5714 views | 9 replies |
zinlover320832
Hi:
I upgraded to 4.5.3 from 4.5. When I select a theme the following appears:
Warning: fopen(../../themes/temp_editing/css/configurable.css) [function.fopen]: failed to open stream: Permission denied in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 99
Warning: filesize() [function.filesize]: stat failed for ../../themes/temp_editing/css/configurable.css in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 100
Warning: fread(): supplied argument is not a valid stream resource in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 100
Warning: fclose(): supplied argument is not a valid stream resource in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 101
Warning: simplexml_load_file() [function.simplexml-load-file]: I/O warning : failed to load external entity "../../themes/temp_editing/theme_settings.xml" in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 104
Fatal error: Call to a member function asXML() on a non-object in /home/content/58/8847158/html/PowerStore/webassist/plugins/styler/styler.php on line 117
Please help.
Thank you,
Stuart
try deleting the themes/temp_editing/ folder, it will be recreated when you try to edit a theme the next time.
zinlover320832
path to folder
I cannot find the folder, please send the path
the path is webassist/themes/temp_editing/
zinlover320832
help
I need to get powerstore upgraded and able to work on. PLEASE help. The url is:
insta-learn.com/powerstore
the correct URL is:
PowerStore/
your server is case sensitive you need to use Capitol P and S in PowerStore
zinlover320832
upgrade
That is fine, what do I do obout fixing the upgrade so I can set up the cart?
Can you be a little more clear on what it is that is wrong? I cant really help fix a problem without knowing what the problem is.
zinlover320832
I am trying to upgrade to 4.5.3.
When I log into the admin, I try to edit a theme and get this:
I followed your advise - the path is webassist/themes/temp_editing/
Nothing.
