Charges calculation
Thread begun 8/07/2012 6:02 am by Suggs | Last modified 8/08/2012 9:19 am by Suggs | 5101 views | 8 replies |
Suggs
Charges calculation
Hi folks,
Need a bit of help creating a charge for a certain product based on one of its column values in the recordset.
I have a table with a column called ChargeType.
I have created a column in the eCart Object Called ChargeType1
The information held in the column field for ChargeType in the database can either be "" (empty), INJ or DISP
If the product chosen has an empty field value for ChargeType then the normal price is to be passed through.
If the product chosen has a field value of DISP for ChargeType then I want it to add 3.89 to the existing price.
If the product chosen has a field value of INJ for ChargeType then I want it to add 7.00 to the existing price
Can you help?
Cheers
Paul
Create a new calculation named truePrice as:
[Price] + (abs([ChargeType] == 'INJ')?3.89:0) + (abs([ChargeType] == 'DISP')?7:0)
you will also need to edit the Total Price calculation from:
[Price] * [Quantity]
([Price] + (abs([ChargeType] == 'INJ')?3.89:0) + (abs([ChargeType] == 'DISP')?7:0)) * [Quantity]
In the cart display page, you will want to replace the Price Display to use the truePrice instead, you can do this using the bindings panel. and in the Checkout code, you will need to edit the checkout behavior to pass the true price instead price to the gateway.
Suggs
Hi Jason,
Thanks for the reply.
The eCart object bombs out with the code added.. could it be to do with the ?'s added?
Also, the Price Display, is that the "TotalPrice"
Cheers
Paul
Sorry, I missed that the column in the eCart object was named "ChargeType1". the calculations should be:
truePrice
[Price] + (abs([ChargeType1] == 'INJ')?3.89:0) + (abs([ChargeType1] == 'DISP')?7:0)
TotalPrice
([Price] + (abs([ChargeType1] == 'INJ')?3.89:0) + (abs([ChargeType1] == 'DISP')?7:0)) * [Quantity]
"Also, the Price Display, is that the "TotalPrice""
In the cart display, there will be a row to show the item price, and a row to show the total for that line item.
The item price in the cart display will need to use the truePrice binding.
Suggs
Cheers for that, however it doesn't add the charges as expected.
The eCart add to cart script has the info coming in from the database recordset as below.
$ATC_itemChargeType1 = "".$row_rsInvoice['ChargeType'] ."";// column binding
It just adds the normal price for all products regardless of whether they are meeting the DISP or INJ criteria or not instead of the added charges for DISP and INJ and normal priced for products that don't meet these two.
And adding the truePrice binding only shows the original item price so lets say its $1, If i then change the quantity to 3 and update, it still shows as $1 but the grand total further down the basket shows the $3 it should be.. this is on an item where it should have added a $7 additional charge based on the ChargeType code
Any further ideas?
to troubleshoot, create a blank page, and add a cart display to it. On the second page of the cart display manager wizard, click the plus button and select All to show all cart columns in the display.
Once the cart display page is created, send a link where i can see the problem and a copy of the cart object file in the WA_eCart folder.
Suggs
Hi Jason,
Did what you said and replicated the page and copied the freshly generated cart code over the existing cart code and it worked a treat so it resolved the issue.
The thing I need it to do is just add a singe charge of $7 to an item that meets the criteria, or $3.89 that meets the alternative criteria no matter how many of that item is in the basket, so for instance the item that meets the criteria for a $7 premium costs 1$, then this would show as $8 ($1 cost + $7 charge) Now if there was 3 of that item it should show in the basket as $10 ($3 dollars for the 3 $1 items and a charge of $7)
Almost there now.
Can you help?
Paul
ok, I guess i misread your initial question.
to add the charge regardless of quantity, you wont need the calculations i had you create yesterday, the true price calculation can be deleted and the Total Price calculation can be set back to the original:
the single charge regardless of quantity can be accomplished using only the Charges tab of the eCart object window.
you will need to create 2 charges:
INJ
Triggers:
"Number of Items With A Specific Column Value"
If the Total Number of Items where "ChargeType1" has a value of "INJ" is ">" a value of "0"
Calculations:
Flat rate Charge of "3.89"
DISP
Triggers:
If the Total Number of Items where "ChargeType1" has a value of "DISP" is ">" a value of "0"
Calculations:
Flat rate Charge of "7"
Suggs
Awesome,
That's done the trick,
Thanks for all your help with this Jason,
