2 forms on 1 page
Thread begun 8/16/2012 6:37 pm by sam308940 | Last modified 8/20/2012 8:16 am by Jason Byrnes | 2426 views | 3 replies |
sam308940
2 forms on 1 page
i have 2 forms on 1 page. 1 has validation the other does not.
the form that has validation, does not validate.
if i remove the other form - then things run just fine.
i dont get it.
attached is 2 files
#3 with 2 forms - no validation
#4 with 1 form - validates
I even tried a page with the 2 forms, where the form with no validation was empty. (ie no fields or info for the form, just the form tag). this also caused the other form to skip being validated.
how can i fix this?
you are using client side validation on the form which uses javascript.
the client side validation references the form using the document.forms[x] collection where x is the index of the form to validate. each form on the page is given a number index, the first for is 0, the second form is 1 and so on.
this client side code was generated for the first form on the page using:
document.forms[0]
most likely, you added client side validation to the form, then added the second form. but since the second form was added to the page before the checkout form that you are validating, it broke the client side validation, because that second form is now before the original one in the DOM.
I dont recommend using client side validation. I recommend using server side validation instead.
your checkout form posts to the card_confirm.php page, so the server validation behavior will need to be applied there.
see this thread for details on adding server validation to a checkout form like yours:
showthread.php?t=21834
gavind
Hi. Is there a link somewhere that shows the whole guide for server side validation?
the form toolkit help documentation includes a section on Server Validation:
wa_fv_19.html
