Styling Dynamic Menu advice please
Thread begun 8/20/2012 2:31 am by CraigR | Last modified 8/20/2012 12:32 pm by Jason Byrnes | 3102 views | 5 replies |
CraigRBeta Tester
I have created a 3 level dynamic menu using CSS menu writer and would like to style it so that if a parent menu item has a child or children, then it is styled with an arrow or a plus sign accordingly.
I have done this with a static menu before, simply by adding the appropriate image to the stylesheet by default, and adding an inline style, such as style="background-image: none;" where no child is present.
Looking at menu.php created from the wizard, I thought the best way to approach this would be to check if the child recordset has any items, and style accordingly, but the recordset for the child items is run after the parent menu is styled.
I have tried moving the recordsets above the menu code but this causes me problems, can you advise on best way to achieve my objective ?
the recordsets will need to be moved, send a copy of the menu.php file so i c can take a look please.
CraigRBeta Tester
thanks Jason.
n.b. data structure for categories is the same as for ps4
an example of how to accompish this is line 51 - 69.
<?php do { ?>
  <li class="parent"><a href="#" style="background-image:url(CSSMenuWriter/cssmw_images/plus.png)"><?php echo $row_menuwriter_ps4categories["CategoryName"]; ?></a>
// MenuWriter Nested Filter Variable
$_POST["menuwriter_ps4categories1_CategoryID"] = $row_menuwriter_ps4categories["CategoryID"];
$MenuWriter_menuwriter_ps4categories1
"-1";
if (isset(
$_POST['menuwriter_ps4categories1_CategoryID'])) {
$MenuWriter_menuwriter_ps4categories1 $_POST['menuwriter_ps4categories1_CategoryID'];
mysql_select_db($database_powerstore$powerstore);
$query_menuwriter_ps4categories1 sprintf("SELECT CategoryName, CategoryID, CategoryParent FROM ps4_categories WHERE CategoryParent=%s ORDER BY CategoryName ASC"GetSQLValueString($MenuWriter_menuwriter_ps4categories1"int"));
$menuwriter_ps4categories1 mysql_query($query_menuwriter_ps4categories1$powerstore) or die(mysql_error());
$row_menuwriter_ps4categories1 mysql_fetch_assoc($menuwriter_ps4categories1);
$totalRows_menuwriter_ps4categories1 mysql_num_rows($menuwriter_ps4categories1);
    <ul class="level-1">
      <?php if ($totalRows_menuwriter_ps4categories1 0) { // Show if recordset not empty ?>
This needs to be rearranged so the menuwriter_ps4categories1 recordset is just after the do statement that starts the loop. and add an ifstatment for the inline style:
<?php do { ?>
"-1";
if (isset(
  <li class="parent"><a href="#" <?php if ($totalRows_menuwriter_ps4categories1 0) { ?>style="background-image:url(CSSMenuWriter/cssmw_images/plus.png)<?php ?>"><?php echo $row_menuwriter_ps4categories["CategoryName"]; ?></a>
CraigRBeta Tester
PERFECT !
Thanks Jason, you've done it again
glad to hear it is working.
