Userid inserts into different user table fields
Thread begun 8/20/2012 2:35 am by sfj6167 | Last modified 8/22/2012 6:56 am by CraigR | 4947 views | 11 replies |
sfj6167
On my admin form (only for admins) I have a dropdown where I select user type.
(besides all the normal user stuff information)
If I I chose ""dealer" I need to capture userID (of the user I`m about to create) and insert that id into the users "dealerID" field
If I chose "salesperson" I need to capture userID (of the user I`m about to create) and insert that id into the users "salespersonID" field
So my question is:
How do I capture the id of the user I`m about to create ?
How do I on "Insert" tell the system, that if I selected dealer it should insert the id into the dealer field of users table
and if I select salespersion, it should insert the id into salesperson instead ?
best regards
Bison
CraigRBeta Tester
The data assist insert record behavior will store the ID of the record that is created in a session variable.
Use this when adding records to the related tables
sfj6167
Hi Craig
I get what you are saying, but the userID in session should go into the users table DEPENDED on what is chosen in the menu/list
If dealer(in menu/list) sessionid should be inserted in usertable field DEALER
If Salesperson (in menu/list) sessionid should be inserted in usertable field Salesperson...
How can I do this ??
again my question is:
regards
Bison
CraigRBeta Tester
Not sure I understand you correctly,
depending on what user type you select, do you insert a row into a specific table or do you have separate fields in your users table to store dealer and salesperson.?
if the former is the case, I would set up an insert behavior for each of the tables, and set up the trigger conditional to the value returned from the select list in the insert form, so that the specific trigger only fires when the appropriate value is chosen.
You did state however, state... "How do I on "Insert" tell the system, that if I selected dealer it should insert the id into the dealer field of users table
and if I select salespersion, it should insert the id into salesperson instead ?"
I am wondering, if this is the case, why do you have two separate fields ?
Sorry if I have misunderstood your objective.
If It helps, attach your database structure so I can take a look.
sfj6167
Hi craig
I`ve attached the db table users.
What I need to do is this:
admins job is to be able to create dealers,superusers and admins.
If he creates superusers and admins, the groupid is suffecient, and works as it should.
if he creates a dealer
on insert the about to be created userID should be inserted into FH_id (Thats the part I dont know how to do)
That way we can always make querys against dealers...
On seperate Insert,update,results,search pages for dealers I need to do this:
Dealer can only create sales persons.
On insert of a new dealer the about to be created userID should be inserted into SA_id (Thats the part I dont know how to do)
On the same insert, since its a dealer, and he is logged in, I need to insert the usersession from the dealer into the about to be created salespersons FH_id. (Thats the part I dont know how to do)
I made a user exampel in the db, so you can see what I mean..
Dealer with id3 has created salesperson(id4), so when he does that, the row for salesperson should have dealers id into the FH_id and salespersons own id into the SA_id.
This way we can easily create quaries against dealers and there attached salespersons...
Also could you explain how to make a trigger that would on conditions trigger the different insert server behaviours...
Best
regards
Bison
CraigRBeta Tester
Hi Bison,
sorry to keep asking questions, but I just want to be clear as to your objectives.
From your table and data, I assume that a salesperson can be created by an admin (eg salesperson with UserID 2), or a dealer (eg salesperson with UserID 4).
You want to link salespersons with the dealer who inserted the record, (what about if salesperson was created by an admin ?)
I am trying to work out why you have 2 separate fields recording FH_id and SA_id.
Am I correct in saying that the only time a value is stored in SA_id, is when the user is a salesperson, and that the only time a value is stored in FH_id is when the user is a dealer or a salesperson, (where the userid of the dealer inserting the record is stored)
What is the purpose of the UserGroupID, does this identify admins/dealers/salespersons ?
If I am logged in, my userid should be stored as a session value.
So If I am a dealer, when I create a salesperson, my userid can also be stored in the record, so you can identify which salespersons I added/
changing the trigger conditions.
When you add an insert record behaviour, the trigger is typicaly something like..
<?php if (isset($_POST["Insert"]) || isset($_POST["Insert_x"]))  {
[[insert code block]]
what you can do is change the parameters of the &#8216;if&#8217; statement so that the insert code is only triggered if (for example) the value of a posted text field equals a desired value. If the criteria is not met, the trigger will not fire.
sfj6167
Hi Craig
You`re right about that it ONLY a dealer that should create salespersons (not admin) sorry my fault.
UserGroupID is for the admin areas for admin,superusers and dealers (maybe a future login and area, will be used for salespersons as well)
regards
bison
CraigRBeta Tester
Could you not have a usergroupid (eg 4) for the salesperson ?
you could also store the id of the currently logged in user in the users table when creating a new record.
This way, you could identify salespeople easily and also to which dealer they are subordinate to, and not need both the FH_id and SA_id fields ?
would that work ?
sfj6167
Hi Craig...
Yes "store the id of the currently logged in user in the users table when creating a new record"
Thats what I want to do, when a dealer creates a salesperson, but that id goes into the FH_ID.
The overall user system I`m building is for a product catalog with a later possibility for making sales competitions between dealerships og between all salepersons.
The UserGroupID is for acces to the different areas
FH_ID and SA_ID is usefull, for query different kinds of rapports and statistics.
We also have a design_type_ID which is for different themes, since the dealerships belong to different dealer chains . This way the theme (after login) will change to whatever colors and logo that dealer belongs to. (This gets set by the admin on dearler creation)
could you give me an example on how a trigger would look like to activate insert of a dealer !
DealerID = 2
Best regards
Bison
sfj6167
Originally Said By: CraigR
Craig - This does not happen...
The "save inserted ID in session" (on the insert server behaviour)is called WADA_Insert_ks_users
but binding that to the SA_ID dont return the id for the "id about to be created"
There is 2 WADA_Insert_users
and 1 WADA_Insert_ks_users
None of them contains the id created on insert!
What sessionname stores the ID created on insert ????
regards
bison
